suspension question
Old Feb 25, 2008 | 11:10 PM
carizma's Avatar
suspension question
ok not sure were this thread should be but yeah i have a suspension question..k i bought tein flexs frm another rx8 owner i put it on then i noticed that my drivers side is more dropped then my passenger side, can i just adjust the coilovers unevenly because there set at the same height on the coilovers, and my second question is if u can just adjust it unevenly on your passenger side to make it even is it bad? or how else can u make it even?
thanks guys
Old Feb 25, 2008 | 11:14 PM
Jack up the car, Loosen up the bolts, drop it an re tifghten.
You have just preloaded the springs correctly.
Old Feb 25, 2008 | 11:25 PM
rglbegl's Avatar
Baned
Ya . . .preload, then tighten bolts.
This has been a MAJOR topic of conversation on here.
search words : preload , pre-load , spring settle , tein
But I cant wait to see the replies on this thread.
Old Feb 25, 2008 | 11:30 PM
carizma's Avatar
thanks
Old Feb 26, 2008 | 12:06 AM
carizma's Avatar
sorry for the noob questions and wat not i searched it but i couldnt find anything that can help me -____- sorry in advanced b4 u guys get mad i didnt understand how do u preload it? im lost sorry..and razz1 which bolts are ut alkin about?
Old Feb 26, 2008 | 01:17 AM
rglbegl's Avatar
Baned
The bolts you need to get to are all behind the wheel, but still not too hard to get to.
Search through all the DIY suspension threads . . you are bound to find a good picture if you need it
Old Feb 26, 2008 | 01:56 AM
raizen82's Avatar
resist, un-learn, defy...
i feel like being nice...
https://www.rx8club.com/showthread.p...hlight=preload
just noticed jedi always came to the rescue on all these preloading threads
Old Feb 26, 2008 | 02:47 AM
auzoom's Avatar
Hmmmmmm.........
yep pre load would be a great thing to search for IF YOU KNEW THAT WAS THE PROBLEM! $%^& my god some people!
There are 2 ways you can adjust the height of the car with flex, one is with the height adjustment (Screw the bottom section out). The other is is to wind the bottom perch of the spring up. This unfortunately has a potentially negative affect so should be avoided as a means for adjusting height. The simplest test you can do is get a tape measure an measure between 2 fixed points on each unit. I use the top spring perch and the bottom locking collar (the one that stops the height adjustment).
Hope that helps.
Old Feb 26, 2008 | 03:28 AM
carizma's Avatar
thanks a whole lot guys
Old Feb 26, 2008 | 04:52 AM
DOMINION's Avatar
I don't buy Kool-Aid
Yeah preload and ride the ground son!
Brokegang
Jan 3, 2016 12:45 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
