View Full Version : Head lights ?
ridged84
11-03-2003, 04:48 PM
Whats the dff between HID and ZEON lights?
eccles
11-03-2003, 05:31 PM
Assuming you mean Xenon, there is no difference. HID refers to the technology - High Intensity Discharge - while Xenon is the gas inside an HID bulb. Two different terms for the same thing.
ridged84
11-03-2003, 05:35 PM
so what your saying is XENON & HID is the samething?
eccles
11-03-2003, 05:39 PM
.Originally posted by eccles
Two different terms for the same thing.Originally posted by ridged84
so what your saying is XENON & HID is the samething? Yep, that's what I'm saying.
Dookie_Rx-8
11-03-2003, 05:52 PM
yes
Gyro 2
11-03-2003, 06:14 PM
This (http://www.rx8club.com/showthread.php?s=&threadid=8280) thread is a good read and should answer all imaginable questions regarding HID headlamps.
I think Eccles is burt out pointing members to the search function....so I will relieve him this time;)
A search containing "xenon" or "HID" will give you hours of reading....:)
Quick_lude
11-03-2003, 06:54 PM
I believe this pic is appropriate.. :D
http://webhome.idirect.com/~jsmialek/jesus_thanks_4_info_1.gif
Gyro 2
11-03-2003, 06:56 PM
hey....I know that guy...
mikeb
11-03-2003, 07:44 PM
has anyone noticed the HID on the 8 started out kinda yellow and now is super white
I love that
Jhouse
11-05-2003, 02:18 PM
thats gunny mine are actually bright purple-white
Chrisbert
11-05-2003, 04:41 PM
The gas can be other inert gases, but Xenon makes light that fits the visible spectrum of the human eye quite well.
High Intensity Discharge is the technology to excite the atoms of the <insert inert gas here> to the point they produce light...think plasma.
neit_jnf
11-05-2003, 04:47 PM
I believe there are a lot of Xenon filled bulbs that are NOT High Intensity Discharge. Xenon is just the gas inside the bulbs, HID is a lighting technology in which the bulbs doesn't have a filament. The super bright bluish light comes from an actual electrical arc jumping across two electrodes inside a Xenon filled special bulb. A very high voltage circuit causes this electrical arc by ionizing the gas as mentioned above.
Jhouse
11-05-2003, 05:43 PM
thats exctly what i was going to say
mikeb
11-05-2003, 05:52 PM
someone fron austrailia changed the HID in their rx8 from the stock 4000k to 8500k making it a purple blue color
does anyone know how much that costs to change out?
sohcpunk
11-11-2003, 08:32 PM
Cost around $180 - $200 for a pair of 8500k bulbs. Now it will not be as bright as the stock 4000k bulbs because the higher you go, the less light output. You can purchase these bulbs at europeanautosport.com
DRx
11-11-2003, 08:45 PM
I noticed that mine are purple-ish white when I first turn them on, but kind of loose the purple after a bit of driving. They dont go yellow though... still really white just no purple.
sohcpunk
11-11-2003, 10:02 PM
i wonder how our headlights compare to the s2000s, there lighting system is great, it changes from yellow to white to blue to puple
English
11-11-2003, 10:23 PM
Here's a graph that will confuse the hell out of some of you...:(
:eek: ...or clear everything up for others.
this is why many parking lot lights look orange, and some flourescent lights look green...it still doesn't tell us why stoplights are always red.
sohcpunk
11-11-2003, 10:25 PM
i think someone on the boards says the rx8 uses 4000k bulbs and I was on the s2000 boards and heard their cars come stock w/ 4500k bulbs, i guess this is the reason why their headlights seems to be flashier than ours
