Renesis in Aircraft
Old Feb 25, 2008 | 05:38 AM
MichaelBrown's Avatar
Renesis in Aircraft
http://www.rotaryaviation.com/renesis_engine.htm
Old Feb 25, 2008 | 01:15 PM
whitebeau's Avatar
Touge Chaser
I've seen a couple sites like this. For plane applications, it looks more reliable since the rotor can still operate to some degree, vs a rod, journel bearing or crankshaft breaking causing a seizure. Ironically i'd feel more comfortable knowing the plane can still be powered while trying to land with a rotory add factors that the Rotory handles constant high rpm's better then a piston design (less wear issues that could cause valve float) with an interference motor that doesn't exist with the rotory.....
Now the biggest irony, is the Air Ports.. carry 102 unleaded octane... but alot of them won't let you drive up your car to fill it up since they don't have a license for road vehicles... but they will let you bring gas containers ITS ALOT cheaper then going to shell to gas up on 102.
Old Feb 25, 2008 | 02:32 PM
RX8-Frontier's Avatar
That's because you're not paying roadway fund taxes on it... Same thing is true at boatyards.
Old Feb 25, 2008 | 02:42 PM
myriadshalaks's Avatar
rot8ing
what are these people talking about here? I don't think I'd want to fly in their plane.
March 3, 2004: Tracy's new Renesis engine arrived , personally delivered by Bruce Turrentine of East Coast Rotary. Of course, nothing ever goes as expected. When Bruce assembled the engine, he used a 3rd gen 13B e-shaft which according to the information available, met all the requirements for the four port Renesis. (Remember, Mazda has published virtually no technical data on this engine). All was well until the engine was completely assembled, when Bruce realized the E-shaft seemed to be too short! The front pulley would only engage about 60% of its bore when bolted in place. So... he ordered a real Renesis e-shaft to be shipped overnight to Shady Bend on Friday. It arrived, and after dinner, the break down and reassembly began. There were dumbfounded looks all around when the Renesis shaft turned out to be exactly the same length as the 13B shaft.
A mad frenzy then ensued to determine what was going on. Skipping all the head scratching and calculations, the bottom line is that Mazda decided that 60% engagement was acceptable. The whole exercise looked like a Chinese fire drill except for one small detail we noticed during the head-scratching. The front main bearing oil hole on the Renesis shaft was moved about .150" forward. This resulted in a mismatch between the oil hole and the main bearing oil groove. Using the original 13B shaft may have resulted in insufficient oil to this bearing.
Laura has been waiting to use this line a long time so she summarized the episode as: Bruce was shafted and Tracy got the shaft!
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
gtorx7
May 30, 2016 07:46 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
