Weird Beep (overload on electric?)
Old Feb 22, 2008 | 07:54 PM
Soapflake's Avatar
This happens quite often and I'm almost sure its the battery, but I figured I'd present my problem and see what you guys think... When I'm driving with my high beams, stereo and the heater on the interior lights get dim and the blower slows down a little. Flip the high beems off and it goes back to normal.
Tonight it started happening and I had the stereo up higher than normal, but this time I heard a beep that wouldn't stop until I either turned the radio down a little, shut the high beams off or shut the blower off. Seems like I don't have enough power which could be an alternator or a battery? Would an alternator be under warranty (I know the battery probably isn't)?
Completely stock 05' 6spd manual. I tried searching, but low power brought up a bunch of threads about low lowend torque and beep brought up redline beep. Sorry
Old Feb 22, 2008 | 08:07 PM
aftermarket stereo? is it a high pitch whine?
Old Feb 22, 2008 | 08:14 PM
Soapflake's Avatar
Stock stereo and no, its a normal sounding beep like when the low tire pressure light comes on, but it stays on (unless I turn the high beems off, slow the blower or lower the volume). I think I might open the battery box tomorrow and see if its the original.
Old Feb 22, 2008 | 08:15 PM
GuyWithRx8's Avatar
Low compression
edit :wait nvm
Old Feb 22, 2008 | 08:16 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Sounds like alternator to me, but just for grins..........check and clean all your connections coming to and from the alternator and battery. It's possible that you have a high resistive contact if the connections have corrosion on them. But don't know why you would be getting a beep?????
Old Feb 22, 2008 | 09:31 PM
mmats69's Avatar
93.5 octane
^what he said. i believe your battery is about to go
Old Feb 23, 2008 | 09:43 AM
kersh4w's Avatar
Hit & Run Magnet
did you try ease off the redline to turn down the stereo, turn off the high beams, or the fans?
Old Feb 23, 2008 | 09:49 AM
Mazurfer's Avatar
Boy..............that better not be it!
Old Feb 23, 2008 | 09:51 PM
Soapflake's Avatar
Haha I don't redline like that anymore (you're referring to the 10 second redline thing I used to do?). I was just ill-informed about the subject and figured it wouldn't hurt it, but i'm glad you remembered
JimmyBlack
273
Feb 10, 2020 10:23 PM
Evan Gray
Nov 24, 2015 01:00 AM
Quiggs321
Sep 30, 2015 05:34 PM
Forevermore
Sep 20, 2015 01:04 PM
