A little air cleaner help, please guys
Old Feb 22, 2008 | 05:57 PM
ChAkA's Avatar
Where's the RUM?
Hey guys. I wanted to first say, I appreciate everyone's info on here. I've read a lot but now it's time for me to make a post.
I have an 04 Rx8, sunlight silver, which has been driven part-time, so it only has 20k miles on it.
I added a K&N Cold Air intake with a K&N filter to it, change the gas door, and that's pretty much it.
I'm going to start driving the car more often and want to do some things to it. I don't want to make it fast, but more for just fun and looks. I'm considering clear corners, inside lights, added guages to the center panel...
I want to know what you guys would advise as my next step. Oh, I also have seen some really nice mirrors on the rx8, any suggestions which one's are good and where i can get them?
Oh, I also have 5% tint all around.
Old Feb 23, 2008 | 07:40 AM
Go48's Avatar
Not to pee on your parade or anything, but consider removing the K&N filter. Oiled filters tend to foul the MAF which can cause irratic idle and poor fuel mileage. Do a search for MAF and read about it.
Aside from that, if you're interested in performance upgrades, install aftermarket anti-sway bars like the Racing Beat units. Best handling upgrade for the $$$. I think there is a DIY in the, doh, DIY section of the forum. Also lots of great info there on other mods people have done.
Old Feb 23, 2008 | 07:50 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yep.....as Go said.......check out the DIY section. Lots of good info in there.
Welcome and please add you location(at least some info) to your profile as it will save you quite a bit of time in the future, because people will know approx. where you are at.
Clears are a must in my book, but opinions vary as always. It's an easy one as is the inside lighting and I would suggest http://www.v-leds.com/Shop/Control/fp/SFV/32481for those.
Old Feb 23, 2008 | 09:27 AM
kersh4w's Avatar
Hit & Run Magnet
clears.. or tints.
just not orange.
i have a k&n drop in, and 2 tanks of gas ago, i average 22mpg over 250 miles. bad mpg?
Old Feb 23, 2008 | 09:39 AM
Learjet_Pilot's Avatar
Paint your brake calipers. That's my next mod, as soon as I find the right color.
Old Feb 23, 2008 | 09:41 AM
kersh4w's Avatar
Hit & Run Magnet
hot pink.
heyarnold69's Avatar
Rotary wanabee
i get 16 hahha
i have a drop in filter.
6mt version though.
Old Feb 23, 2008 | 10:04 AM
IcarusX8's Avatar
i've lost my mind
Clear corners. NOW!
Old Feb 23, 2008 | 10:37 AM
Go48's Avatar
"Oiled filters tend to foul the MAF..." Notice the word tend. The oil hasn't reached your MAF--yet.
Old Feb 23, 2008 | 02:19 PM
Get some stickers. It makes it go faster. NOT
Old Feb 26, 2008 | 01:43 PM
ChAkA's Avatar
Where's the RUM?
Wait, so I would have to take the filter out and replace it with what? Can I even do this myself? Where is there a NOOB tutorial in changing filters? what is a good filter that won't foul the MAF and my gas mileage?
Old Feb 26, 2008 | 01:50 PM
Go48's Avatar
You can revert to the OEM intake which has a dry paper filter element. However, if you don't over oil the K&N element, you may not have a problem. Check your MAF/IAT sensor unit periodically to see if it is clear of oil. See the shop manual for the location of that sensor.
Old Mar 6, 2008 | 07:18 PM
ChAkA's Avatar
Where's the RUM?
So I should change the entire Intake? I did some research and I read that the Revi Intake is best for the rx8, is this true? Is it worth 300 and osmething bucks to buy it and another 100 to install it?
Can't I just let the K&N Intake and filter stay there? What will be the downside?
Old Mar 6, 2008 | 08:19 PM
raizen82's Avatar
resist, un-learn, defy...
$300+ for something that adds so little... i'd rather spend that on AF/RP shifter and stick with stock air intake. i took out the panels inside the box though.
Old Mar 6, 2008 | 09:22 PM
mikesol's Avatar
gas kilometerage
You can always pick up a bottle of MAF cleaner for cheap and clean the damn thing.
Old Mar 10, 2008 | 01:06 PM
ChAkA's Avatar
Where's the RUM?
yea, I think imma go with cleaning the MAF. I like the sound of the K&N and have no patience to replace it for 300 bucks!. I can't find the stock intake either, which means i'm pretty much screwed...
Have any of you replaced the stock CD player with a 6-disc changer?
uZu
Dec 30, 2015 12:35 PM
GK1707
Dec 2, 2015 10:01 AM
8is>enuff
Sep 24, 2015 08:57 AM
reni04
Aug 21, 2015 01:52 PM
ktec
Jul 29, 2015 01:17 PM
