West RX-8 Forum Serving CA, NV, AZ, HI
San Bernardino monthly Mazda meet and drive.
Old Mar 10, 2008 | 04:55 PM
  #476
kwescott's Avatar
One ball, corner pocket
Originally Posted by lesper4
updated.
zootender...still needs to pay for calendar and schedule a time with Lesper4 to arrange pickup.
ghost...still needs to pay for calendar and schedule a time with Lesper4 to arrange pickup.
jedi54....paid, and I believe he is making arrangements for shipping.
Old Mar 10, 2008 | 04:56 PM
  #477
kwescott's Avatar
see you at 530 loren.
Old Mar 10, 2008 | 05:42 PM
  #478
lesper4's Avatar
T-29 years and counting
Sherri will be stopping by yorru place around 9, since we may still be there, to pick up the calendar
Old Mar 11, 2008 | 12:17 AM
  #479
(protege5)
OK here are pictures of my drivers side front tire. as you can see the inside corner of the tires is cupping(?) this has only occured on this tire. all tires including this tire were the correct PSI except for the right rear which was very low. i went ahead and put this tire on the drivers side rear and i think it should be fine since those tires are ridig flat as apposed to the front that rotate. any idea why this has happened. when it gets lower i think i will change it out but i think it is ok for now? oh and the location where the treat is showing through is the only location (about 1").
what are your thoughts?
Cupping is from Alignment.
Damage on the inside is from a bad suspension set up or broken suspension.
Your tire rubbed the perch for the springs.
Old Mar 11, 2008 | 12:01 PM
  #480
rglbegl's Avatar
Baned
Good morning all
Old Mar 11, 2008 | 12:02 PM
  #481
kwescott's Avatar
Originally Posted by Razz1
Cupping is from Alignment. Loren, did you have the alignment checked on the Protege....have you ever had the alignment done at that car?
Damage on the inside is from a bad suspension set up or broken suspension.You may not see the leak, but the strut could still be blown....is this right guys?
Your tire rubbed the perch for the springs.I would suggest you check this Loren, this is likely to have happened
These were all very good points Glen...Loren, I'm sure that one of these is most likely the cause. When you had described the tire to me, I had a different image in my head. but when I saw the pics, it seriously looks like something cut the tire. I'm thinking along the lines of Glen's suggestion that the tire may have hit the spring perch and that you may have a bad alignment and/or bad strut.
Old Mar 11, 2008 | 12:22 PM
  #482
lesper4's Avatar
yeah i thought it was the strut /spring assembly but it wasnt touching when i did the rotation. it may have settled now so i will check it again when i get home. if the strut is blow how would i be able to tell?
Old Mar 11, 2008 | 12:44 PM
  #483
Detrich's Avatar
幹他媽!
good am everyone
Old Mar 11, 2008 | 01:03 PM
  #484
the car's suspension would feel off a bit. When the struts go, they seem to get bouncy.
You still on OEM struts?
I have a replacement set if you want. I've been meaning to throw them out since they're just sitting in my garage. Let me know if you want them.
Old Mar 11, 2008 | 01:04 PM
  #485
Morning Gerry, how goes it? Any word on the employment situation? (last day?)
You going to take some time off and relax a bit or are you going to jump right into interviews / job hunting?
Old Mar 11, 2008 | 01:17 PM
  #486
kwescott's Avatar
That is why Jessie asked if the strut was "oily" looking or if it looked shiney/greasy...all signs that the strut is leaking and bad. You most likely see a stong black mark, and it will be really dirty in one area if it has gone bad.
Jedi is right as well, the suspension will feel "off"....but since this is not your daily driver, it may be hard for you to diagnose....maybe asked Mirna if the car has felt any different lately...more bouncy, or if one side seems to be more responsiive or sluggish than the other.
The only other way of telling if the strut is blown, is pulling it off the car and comparing it to the strut on the opposite side of the car. With the strut tower assemble taken apart (pulling the spring off), you should be able to just push the strut on the ground to collapse it....if it is blown, you will have no problem collapsing it...and it may not even come back up (rebound)...or it may rebound too quickly.
Jump in here guys....
Jedi, he needs an assembly for the protege....this isn't for his 8.
Old Mar 11, 2008 | 01:21 PM
  #487
whoops, missed that part.
Old Mar 11, 2008 | 01:24 PM
  #488
lesper4's Avatar
Ok Well Is Sounds Like I Have Enough To Do When I Get Home This Evening. I Will Let You Guys Know More, Thanks.
Old Mar 11, 2008 | 01:34 PM
  #489
Detrich's Avatar
幹他媽!
well, my boss is flying to NY next week to meet w/ the head of Warner Bros' IT dept. and, from there he'll determine which "transition team" he'll need to get New Line moved over to Burbank. i'm hoping that i'll get a spot on that team, because at least then it will extend my employment here for a while. and, i'll still get my severance after that. it's unlikely WB will have jobs for us though- since Time Warner is cutting across the board, which means even those guys are at risk of having some cut-backs & lay-offs.
and, in the meantime, i'm just going to be passively looking and hoping that i find something suitable nearby. would start hating life if my commute became 2 hours each way.
Old Mar 11, 2008 | 01:40 PM
  #490
Keith's got this one nailed on the head. I don't want to sound like an *** when I say this but I'm just going to spit it out: Mirna might not be able to tell if the car has felt a bit 'off'. My experience with most people is that they don't always pay attention to all the little things on a car and most cannot fell the difference with a blown strut; especially if it's in the rear.
I'm thinking the true test is going to be removing it and manually testing it
Old Mar 11, 2008 | 01:48 PM
  #491
lesper4's Avatar
(no offense taken) she wouldnt!
Old Mar 11, 2008 | 01:51 PM
  #492
rglbegl's Avatar
Baned
So anyone want an 8'x10' booth at the auto show next month? - $1100 is my cost.
Guess who just got put in charge of selling booth space?
I say we fill it up with mazda people.
Old Mar 11, 2008 | 01:54 PM
  #493
what auto show?
Old Mar 11, 2008 | 01:55 PM
  #494
rglbegl's Avatar
Baned
The IE auto show
We have everybody but FORD . . .those bastards!!!
We even have a car collector bringing a few of his million dollar cars
Old Mar 11, 2008 | 01:59 PM
  #495
Detrich's Avatar
幹他媽!
how do u like the Toyo T1R's compared to the Khumo MX's jorge? for some reason the khumo's look wider & meaner to me. is this correct?
Old Mar 11, 2008 | 02:01 PM
  #496
kwescott's Avatar
An Auto Show in the IE has only got to attract 3 different kinds of people. People who like old Camaros....people who like old Trans Ams.....and then those that need commuter cars (cause we all drive fricken 80 miles to get to work)...
Old Mar 11, 2008 | 02:03 PM
  #497
kwescott's Avatar
oh, shoot...forgot those that like old mustangs......guess there is four groups that will show up. But of course, there has to be no cover charge/entry fee, and outside beverages and open containers must be allowed to be let in. Cause you know us IE people aint going to pay 4 bucks for one of them fancy beers in a plastic cup. We like our beers in cans or bottles...cause those are more fun to shoot at (who wants to shoot a plastic cup....really?....anyone?)
Old Mar 11, 2008 | 02:17 PM
  #498
the T1R's are proving to be great tires, I now see why so many people use them on afterket wheels.
The Kumho's did have a more agressive tread pattern to them though.
Here's my recommendation from what I've seen so far.
If you're driving almost daily: Toyo. Better tread life
If you don't drive daily and want an agressive tire: Kumho MX is the way to go.
Love 'em both to be honest, I can easily see myself getting another set of Kumhos if I keep driving as much as I'm driving now.
However, if I go with new wheels I'll probably go with Toyo's simply because I don't want to be shelling out $1,000 in tires every year.
Gerry: for you, I'd go with the Kumho in 245, 40, 18. You'd LOVE them.
Old Mar 11, 2008 | 05:22 PM
  #499
Detrich's Avatar
幹他媽!
COOL BEANS. thanks jorge.
Old Mar 11, 2008 | 06:24 PM
  #500
Detrich's Avatar
幹他媽!
wow, lively bunch today...
that said- just paid my dmv reg renewal on the 8. $210 buckaroos. what is everyone else paying?
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
