Red Line Limited Slip Differential Fluid
Old Feb 19, 2008 | 06:56 AM
rotaryPilot's Avatar
Very satisflied with Red Line LSD fluid.
However I still wonder what is the difference between viscosity 75W-90 of Red Line and SAE 90 that the workshop manual recommends for Limited Slip Differential ?
Old Feb 19, 2008 | 08:25 AM
Jax_RX8's Avatar
Got Another Rotary
They are the same thing - 90 weight is the operating temperature rating for SAE90 and a 75W90.
The only difference is that a 75W90 is not quite as outrageously thick when cold (but still thicker than when at operating temp).
Since Redline uses "Ester" (Group V) oils as there base - they naturally have a wide temperature range and generally require little to no Viscosity Index Improvers (VIIs) to achieve the 90 weight at operating temp while being better flowing when at room temp (75W), which is good as VIIs can shear over time causing the oil to thin out and the base oil cannot.
RL is a superb product, amongst the top 3 or 4 oils you can buy, use with confidence.
Old Feb 20, 2008 | 05:43 PM
diabolical1's Avatar
i'm the undead
your knowledge of these lubricants seems pretty comprehensive - crossing brand names. i am very impressed.
Old Feb 20, 2008 | 07:40 PM
Jasonawojo's Avatar
I put the Redline LSD fluid in my diff a few thousand miles ago, and all is well.
Old Feb 21, 2008 | 02:49 PM
Jax_RX8's Avatar
Got Another Rotary
Thanks! It has become quite a hobby of mine and something I enjoy researching and learning about. Hopefully the info I share provides at least one perspective to consider.
Skyl3r
Dec 2, 2019 04:51 PM
BigMikeATL
May 26, 2016 12:31 AM
Kanthinar
Dec 21, 2015 01:24 PM
Bomba
Jul 22, 2015 06:46 AM
Belalnabi
Jul 17, 2015 07:48 PM
