at what mileage did you replace your brakes
Old Feb 17, 2008 | 07:43 AM
darren90909's Avatar
Old Feb 17, 2008 | 07:44 AM
funny ... Read your owner's Manual.
Spinning Sushi's Avatar
I <3 Sushi
Haven't replaced mine and I'm at 23k.
Oh...
Originally Posted by nycgps
Search !
Old Feb 17, 2008 | 07:51 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Ummmmmmmm.............when you need to do so. I haven't had to do mine yet.
Are you asking because someone said you needed new brakes or what?
Old Feb 17, 2008 | 07:52 AM
He asked because he is too lazy to read the manual and search.
Old Feb 17, 2008 | 07:59 AM
Mazurfer's Avatar
Why.....Oh why, did I give you that chance?
Old Feb 17, 2008 | 08:11 AM
JRichter's Avatar
Void Where Prohibited
At 35k miles with same brakes...
Old Feb 17, 2008 | 08:15 AM
mysql101's Avatar
darren90909, don't mind these a-holes. I'll give you the 411 buddy. The truth is that the Rx-8 needs the brakes changed every 9,000 miles. These forum people don't want to tell you because they were suckered into buying a RX-8. I suggest getting a Corolla instead.
Old Feb 17, 2008 | 08:20 AM
Mazurfer's Avatar
Oh..........that was helpful!
My question still stands..............why does he want to know? Is it because someone is trying to rip him off and says he needs new brakes when he doesn't?
We all know(or we should know) that there are a ton of variables to this equation, but the simple fact of the matter is, that the system(for the most part) will let you know audibly when it's time(for a pad change that is).
Old Feb 17, 2008 | 08:27 AM
well, I have 40,000 miles and as far as my visual inspection it looks like I have 60% brakes left on rear and 50% on front, I was thinking that I should be needing new brakes by now but I wanted to compare with all of you grumps and know-it-alls.
Old Feb 17, 2008 | 08:28 AM
so my question still stands ???
Old Feb 17, 2008 | 08:33 AM
Mazurfer's Avatar
Okay cool............This is my opinion.
At 40k miles I would go ahead and put new pads on, but it's not absolutely needed. Once the pads wear down sufficiently they will squeal as the metal wear indicators will let you know.
That's just me.....it kinda depends on whether or not you are strapped for money, or if money isn't an issue. But...............40k on a set of pads is getting up there pretty high.
Also matters if you drive(brake) hard are tracking the car.............etc.
Old Feb 17, 2008 | 08:35 AM
chrism's Avatar
Misfit Moderator TnC
i replaced mine at about 15k...by choice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!
Old Feb 17, 2008 | 08:51 AM
I can afford new brakes but I guess common sense tells me why when I still have 50% left. I usually waited until 20% left on other cars I have had. retirement is sneaking up on me and I need all the help I can get
so maybe I should start a new post
who has over 50,000 miles and still has the original brakes
Old Feb 17, 2008 | 08:57 AM
templar99's Avatar
Man About Town
I'm at 52,000 miles with no brake replacement yet.
As for buying a Corolla instead, I say, yes by all means buy a Toyota, and replace the transmission every 9,000 miles.
Old Feb 17, 2008 | 09:04 AM
lesper4's Avatar
T-29 years and counting
just did mine at 33k but the fronts only.
Old Feb 17, 2008 | 09:11 AM
kersh4w's Avatar
Hit & Run Magnet
im at 32k and replaced the pads on the 3 of my 4 rotors. my friend REALLY overtorqued a nut (probably 175ft/lbs+) on my rear passenger side tire. even a breaker bar and impact socket sledgehammered into place didnt work. the breaker bar was even bending.... after 10 or so minutes of pushing. the lug just gave way. so now i have a round lug...
Old Feb 17, 2008 | 12:36 PM
AmKorp's Avatar
What's up with the corolla bashing? I know the RX8 is a great car, but it will never get even close to becoming as popular and reliable as a corolla! I dunno what kind of corollas you've been buying (maybe fake branded ones made in the phillipines) but replacing a transmission on those cars is unheard of. Hell, I've got a 1992 Corolla with automatic transmission and 580, 000 KM (~ 360, 400 miles) on the original engine and tranny and it runs better than some of the RX8s on this forum (read engine failures and flooding)
And to the OP : why in god's name are you asking questions about when to change your brake pads when you have already taken a look at them and decided that they didn't needed to be changed!?!? That totally defeats the purpose of the initial question...does it not? You clearly stated that you have approx 50% on them left and that you don't change them until they are down to 20%. So that should be the answer you are looking for. Or maybe I'm missing something?!?!
Old Feb 17, 2008 | 12:38 PM
mysql101's Avatar
You completely misread it. The corolla was pointed out as a more "regular" car that might not be as confusing to a regular user.
I know a coworker (female) who owned a corolla. She never knew she was supposed to change the oil more than once a year. The car ran great. If she owned a RX-8 the engine would have seized up within 2 months.
Old Feb 17, 2008 | 12:42 PM
Easy_E1's Avatar
Replaced my front pads and turned the rotors at 43,000 miles. Wasn't much left of the inside pad. 3/32nds maybe.
Mostly depends on your driving habits as to how long they last.
Old Feb 17, 2008 | 12:44 PM
AmKorp's Avatar
Oh no, I wasn't commenting on your post mysql, I understood what you were trying to tell the OP. I was responding to the post that I quoted (replace tranny ever 9000 miles remark).
Old Feb 17, 2008 | 12:48 PM
mysql101's Avatar
ah.
I have another coworker with a ~2000 model corolla, he's got about 160k miles on it, and it has an oil leak. The engine has literally had no oil reading on the dip stick several times, and made clanking noises before he refilled it with oil. He still travels cross country in it for sales meetings without issue. It's a damn work horse if I ever saw one.
Old Feb 17, 2008 | 12:55 PM
AmKorp's Avatar
Tell me about it! My father refuses to buy a new car. He got the 1992 corolla used in 1997 and he's been driving the heck out of it for the past 10 years. He keeps saying that if he can get it to 999,999 that he's gonna take it back to toyota so that they can put it in their headquarters on display. He's also hoping that they'll give him a new corolla as a prize!!
Old Feb 17, 2008 | 01:30 PM
kersh4w's Avatar
Hit & Run Magnet
wishful thinking. but it may just work. lol.
testament to their engineering.
Old Feb 17, 2008 | 01:43 PM
Tim Tim Tim's Avatar
auto suckkssssss
Why would you replace your brakes before they were due? The rx8 brakes are more then sufficient for your every day drivers and weekend track warriors. I personally wouldn't let the pad itself get below 1/8 of an inch.
