View Full Version : Oil Pressure Sending Unit Threads?
tdiddy
02-16-2008, 09:38 AM
Anybody know what size and pitch the threads are on the OEM oil pressure sending unit? I am trying to find a fitting but can't seem to find the details on the thread. Thanks!
dannobre
02-16-2008, 09:51 AM
It's some metric version of 1/8NPT....someone else probably knows what :)
!/8NPT will fit if you taper it down more with the die...
tdiddy
02-16-2008, 10:08 AM
Thanks! Yes, its not 1/8 NPT. I have tried that. I thought about using a die but if you know where to look you can get just about any fitting. I want to try to get the right fitting before going that route.
dannobre
02-16-2008, 11:01 AM
It's probably M12X1.5T......
Well...it's not:-) Might be 1/8BSPT??
You can buy autometer adapters from 1/8NPT to 1/8BSPT......Saw them today at an autoparts place....didn't try the adapter to see if it fits though :)
tdiddy
02-17-2008, 09:37 AM
I'm thinking its closer to M10x1.5. I am going to try picking up a couple of bolts this week from the hardware store to see if I cant get any closer to the actual thread. If that doesn't work I will use a die on one of the 1/8 NPT fittings I already have.
dannobre
02-17-2008, 12:18 PM
M10X1.5 isn't a tapered pipe thread....
