Engine kinda hiccups at idle.
Old Feb 14, 2008 | 10:24 AM
Vasichko's Avatar
I have had this issue with the engine kind of sputtering or having a slight hiccup at idle for the past month or so. The idle on the tach stays solid but I can physically feel this when Im sitting at a light.
My car has 29,8XX miles, 05', MT.
1000 miles ago I changed the plugs, coils, and did magnecor wires.
Motor mounts changed about 2000 miles ago.
I havent checked the wires on the plug yet, but I made sure that when I installed them they were seated good.
Should I be worried?
Old Feb 15, 2008 | 04:02 PM
VOODOO8's Avatar
Hermitage Holdout
Anything change recently in gas grade/source being used; weather been colder/wetter than what your used to; or other factors that might be more circumstantial than mechanical/electrical?
Old Feb 15, 2008 | 04:35 PM
MazdaManiac's Avatar
Usually an ignition thing.
Coil, wire, plug.
Old Feb 15, 2008 | 04:45 PM
Blackfd3's Avatar
Sit in your car and slighty ease down on the gas ped. When you do this, if you feel the car kind of sputter it sounds like you have miss. Check coils, plugs and wires. If this is not it, post back and I will get you more info.
Old Feb 15, 2008 | 10:04 PM
DOMINION's Avatar
I don't buy Kool-Aid
To the OP, Try cleaning your MAF Sensor
Old Feb 16, 2008 | 05:22 PM
Vasichko's Avatar
Yeah I was hearing/feeling it miss.
The wires and plugs only have about 1000 miles on them.
The coils might have 5000 or so miles on them.
I cleaned the MAF and reset the PCM, so far seem to be running ok.
Old Feb 16, 2008 | 08:01 PM
put stock plug wires back on..
Old Feb 17, 2008 | 11:05 AM
Vasichko's Avatar
You think my Magnecores could have been an issue?
Im wondering if I may have a clogged cat?
I think its been on there for about a year, but then again I really havent felt a loss of power or anything that I can tell.
Old Feb 17, 2008 | 09:19 PM
cat problems dont show up at idle.. and my guess is you have the stock wires sitting aroung..
Old Feb 17, 2008 | 09:36 PM
Omega8's Avatar
I have a 2006 GT MTX, only 7500 miles on it, not driving it at the moment, as it is stored for the winter. More or less completely stock, no engine mods yet.
But I have experienced the same "sputter", but it only happens when I first start it after it has sat at work all day or overnight. When I first start it, it's super smooth at idle. If I give it a little gas in neutral while idling before driving off, it will do that "miss", or sputter that Vaschiko described. Then if I let off and repeat, it does it again, but only at HIGHER rpms than the previous rev. After a few of those, it's gone. Plus, if I take off, there's no hint of it (i.e, under load), whether I waited after starting or started out driving right away.
Wondering if cleaning the MAF sensor will work for me too... Anyone think this sounds similar to Vaschiko's symptoms? Other than this, the car is flawless.
ironj221
36
Jan 20, 2026 08:28 PM
vapor2
Nov 3, 2020 03:38 PM
uZu
Dec 30, 2015 12:35 PM
Rx808BI
Aug 9, 2015 10:06 AM
dbarber
Jul 25, 2015 01:34 PM
