wassup_nuthin
02-12-2008, 10:42 PM
Ok so i have my midpipe in today and the check e light came on. now i know it will come on, but when i go wot the engine light blinks, is that normal?? the car runs fine but the engine light will blink when i accelerate hard w/ it.
chickenwafer
02-12-2008, 10:43 PM
No, blinking indicates a problem. Pull the code, you probably have a misfire.
wassup_nuthin
02-12-2008, 10:45 PM
hmmm.. ok well what do i do w/ a missfire??? how to fix?
chickenwafer
02-12-2008, 10:47 PM
Possibly your ingition coils are on the way out. Search for "misfire", it will come up with a bunch of results
wassup_nuthin
02-12-2008, 10:48 PM
ok well ill pull the code tom. but the car runs very well no idle prob. and accelerates really good. but like i say it blinks when i get on it... is missfire bad w/ the 8?? not to sound newbi but im not for sure what you mean like a spark plug is bad or what
wassup_nuthin
02-12-2008, 10:49 PM
oh ok well in that case , i orderd mazsport ignition about a week and a half ago so im good. but would my midpipe cause it to missfire b/c it didnt befor i put it on. just right after it was installed it started to blink
wassup_nuthin
do i need to be worried about dirving it. *hurting the motor*
nycgps
02-12-2008, 10:59 PM
I know my car's condition, it happened to me. No concern.
For you, I dont know, dunno ur car's condition.
chickenwafer
02-12-2008, 11:01 PM
Just saw your other thread and noticed you installed a new crank pulley. That is more than likely the culprit here.
Did you reset your eccentric shaft profile?
wassup_nuthin
02-12-2008, 11:27 PM
ok i dont know if your messing w/ me w/ the hole profile w/e. what is it how do you do it?? lol
chickenwafer
02-12-2008, 11:49 PM
Tap the brake pedal 21 times as fast as you can and punch a midget in the face. The oil pressure gauge will sweep and that will reset your e-shaft profile sensor.
wassup_nuthin
02-13-2008, 12:26 AM
ok i got you never heard it called that but its more like 8 times w/ in a few seconds but ok thanks. imma do that and unplug the bat for awhile
DOMINION
02-13-2008, 12:32 AM
:lol: What Chickenwafer ment to say was turn your key to the on position then hold the trip reset button and pump the brake pedle as fast as you can till the oil pressure gauge sweeps to the middle. Then your good :)
mmats69
02-13-2008, 11:29 AM
http://www.rx8club.com/showthread.php?t=27548
Read post #3
wassup_nuthin
02-13-2008, 01:08 PM
hey guys just an update reset the ecu and did the brake tap. and everything works great no check engine no blinking. thanks guys!!
mmats69
02-13-2008, 04:31 PM
good deal. keep an eye on it just in case
