stock sway bars weight !
Old Feb 12, 2008 | 03:19 AM
rotaryPilot's Avatar
Well thinking on installing Racing Beat Sway bars but I believe that those sway bars may be a lot heavier than stock. Specifically,
RB sway bars
9.7 lbs front,
3.1 lbs rear.
Does anybody knows the weight of stock sway bars in order to compare?
OEM sway bars
???lbs front
???lbs rear
Also I am thinking of OEM suspension with RB swaybars. Do you think that this combo will have any problems? or will not perform well?
Old Feb 12, 2008 | 06:10 AM
CTrx8's Avatar
space for rent
one of the sticky threads over in the tech forum:
https://www.rx8club.com/rx-8-racing-25/weight-stock-rx8-parts-81791/
Front sway bar 6.3lbs (didn't see the rear in there).
Old Feb 12, 2008 | 07:11 AM
Thanks ^. However there is no weight for rear sway bar.
For the front the difference is so small only 3.4 lbs heavier
RB sway bars - OEM sway bars
9.7 lbs front - 6.3 lbs front
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Brokegang
Jan 3, 2016 12:45 PM
OfficerFarva
Dec 5, 2015 10:53 AM
Zube6115
Sep 30, 2015 12:57 PM
Steve Dallas
Sep 19, 2015 09:39 AM
