Mazdaparts.com LCD/Navi kit
Old Feb 9, 2008 | 01:22 AM
robel82's Avatar
Yippie ki yay
Quick q.... Does this thing come with the mechanics for automatic retraction or is it manual by hand? For $400 I would hope so but it doesnt look like it according to the pics. BTW I'm build a car pc and want to use this for my display.
http://www.mazdaparts.com/ProductDet...000-1159943707
Old Feb 9, 2008 | 01:46 AM
RWagz's Avatar
Piston-free 07.11.2007
Not motorized, as far as I know.
Paging MM for final answer.
Old Feb 9, 2008 | 05:34 AM
no motors,
simple is good..
Old Feb 9, 2008 | 02:45 PM
robel82's Avatar
Yippie ki yay
ok thanks guys. Anyone know what the quality is like?
Old Feb 9, 2008 | 03:26 PM
shakeyourbrakes's Avatar
i had the setup..do a search for "my lcd setup" theres a vid of me opening and closing it. Quality is ok...the brackets to hold the lcd are metal. Never felt perfectly solid to me as far as where the lcd mounts to the brackets that rotate it up, but overall it was a good buy.
Good luck
Old Feb 9, 2008 | 05:00 PM
mdr's Avatar
mdr
How much room is there in that hood? I know it will hold a 7 inch screen but how thick? What if you took the flip mechanism out could you put a 1 din unit under there and just use the hood to hide it when not in use?
Old Feb 9, 2008 | 05:31 PM
nah not a lot of room in there, but i guess you could cut the bottom out of the tray the lcd fits in and try to fabricate something. A single din might work though its about the size of a lcd. Basically theres just enough room for a lcd to lie flat..i forgot how thick mine was, im guessing around 2.5 inchs max?
Then again, why would you want a single din player mounted on top..where would the monitor be?
Old Feb 9, 2008 | 05:55 PM
robel82's Avatar
Yippie ki yay
I saw your vid shake and I decided against that setup. Looking at this now instead...
dash kit
In-dash touchscreen
Old Feb 9, 2008 | 07:48 PM
mdr's Avatar
mdr
The monitor is a pop up monitor like robel82 posted a link to with full GPS dvd cd mp3 and bluetooth built in. I want to be able to hide it though instead of using the single din hood like he posted a link to.
Old Feb 9, 2008 | 09:20 PM
ya i doubt it ...1/2 din you could get away with, full din I doubt you could get it to fit unless you hacked out the bottom of the tray. $350 is pretty steep though for basically a sliding cover at that point. Fabricate your own somehow out of the dash piece, two pieces of abs plastic with notches to slide over each other somehow could work out to a compartment that would fit a hidden unit.
Good luck on that pc setup from this thread, let me know how that turns out. Im not a big fan of that dash piece din thing, but with a pc itll prob be pretty good
Old Mar 12, 2008 | 05:45 PM
rafaga's Avatar
Hey robel82...did you go with the 1 din dash piece? please post pics if you do so...i'm also considering that option.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
