Amplifier question
Old Feb 8, 2008 | 04:01 PM
JGR4444's Avatar
GR
Amplifier question
is it possible to hook up two amps at the same time? Im planning on hooking up a 300 watt amp for two 6x9's that i have put in enclosures and one 800 watt amp for a sub... will this be ok for the battery or will i need a stronger batter?
Old Feb 8, 2008 | 04:22 PM
LoSx's Avatar
Is it possible... yes...
The alternator realistically probably can not supply more then a spare 50 amps which equates to 600 - 700 watts...
Now since you wont be driving the sub at full load all the time this seems reasonable but you could always add a cap to it for large notes but a cap just is a bandaid...
I'm sure a yellow top with a cap can take this load just fine...
You could always benefit from a HO Alt but at that level I would probably not
Old Feb 8, 2008 | 04:45 PM
DeViLbOi's Avatar
The devil made me do it
Why on Earth would you be trying to cram 300W into 2 lowly 6x9's? Is there even a set of 6x9's on the market that can take 300W RMS?
Old Feb 8, 2008 | 10:40 PM
Revvittupp's Avatar
No, but I doubt any of these numbers are RMS, which makes this all feasible with little to no change in the charging system.
Old Feb 9, 2008 | 04:20 PM
JGR4444's Avatar
GR
yea none of that was RMS.... is there a stronger alternator that i could buy maybe because my car has trouble starting usually anyways... whats the price on one?
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
