How to adjust clutch engagement/disengagment point?
Old Feb 8, 2008 | 08:53 AM
Vasichko's Avatar
Im wanting to adjust the clutch engagement/disengagement point.
When I start my car in neutral and let it out I can feel some movement.
Also when the revs are high and I push the clutch in and shift, it is still feeling like it is grabbing.
My motor mounts should be okay since Mazda replaced both of them about 2k miles ago, or at least the work order says they did. Maybe this will fix some of the shudder I feel when going from 0 throttle to light throttle?
Old Feb 8, 2008 | 08:55 AM
ja9^'s Avatar
if u meen the "rocking" forwards and backwards when on/off the throttle Im experiencing the same thing.. have had my mounts changed too..
Old Feb 8, 2008 | 08:56 AM
ja9^'s Avatar
..and i have the same feel with the clutch, at least sometimes.
Old Feb 8, 2008 | 08:58 AM
If you're on a flat ground. your car should NOT move at all.
There is a good chance that your clutch pedal bracket is failing. You might want to look into that.
Old Feb 8, 2008 | 09:38 AM
Vasichko's Avatar
What is a good way to look at this?
Old Feb 8, 2008 | 11:09 AM
staticlag's Avatar
The Professor
Shifting engaugement point.
Sounds like air in the clutch line. When's the last time it's been bled?
Old Feb 8, 2008 | 11:12 AM
Vasichko's Avatar
Last time it was bled was about a month ago, when I bled it there was no air in the lines at all.
The clutch bracket looks solid.
These issues didnt start until the dealer replaced my throw out bearing and I had them put a new clutch/flywheel combo in (ACT). Ever since that I notice my 2 to 3rd is very notchy unless I wiggle it in neutral before going to 3rd.
Ive told them and took it there and they keep saying its the clutch, blah blah blah, its normal blah blah blah.
Vasichko's Avatar
Oh and tranny and diff fluid was done about 2 weeks ago, I had Rotary Performance do it for me since I was feeling a bit lazy.
Old Feb 8, 2008 | 11:13 AM
staticlag's Avatar
The Professor
You change the adjustment point by changing the piston setting.
Look at the clutch pedal and you will see a double nut assembly. untighten the lock nut (9-10mm?) and turn the other nut (8mm I think) clockwise to tighten the pedal and raise engaugement point (towards you). The other way to lower the point towards the floor. There should be no constant load on the pedal, so make sure that whatever you tighten it to should have 1/16-1/8 inch of free movement when there is no pressure on the pedal
Old Feb 8, 2008 | 11:19 AM
MazdaManiac's Avatar
You can take out all of the slack on the adjuster - just keep turning the rod until you see it begin to push the face of the piston in and then back it out a half-turn.
Its worthwhile to get under the car and check the slave cylinder.
Those can start to fail gradually. Look for brake fluid seeping out from the rubber cap.
Old Feb 8, 2008 | 11:20 AM
Vasichko's Avatar
Just checked it, looks fine.
Maybe what Im experiencing is movement in the drivetrain?
Kinda hard to describe, when at high rpms I push the clutch in and shift and it seems like the clutch is still wanting to grip.
I guess I will try to bleed the line again. I bled it from max to low line on the reservoir maybe 3 - 4 times. There were no big air gaps, but some tiny bubbles here and there.
Old Feb 8, 2008 | 11:21 AM
Vasichko's Avatar
You think I could have an issue with the slave cylinder at 29k miles?
Old Feb 8, 2008 | 11:24 AM
staticlag's Avatar
The Professor
Could also be your technique, shifting a worn clutch is different from shifting a new clutch. Engaugement points change because of the size of the new disk vs the worn disk.
Old Feb 8, 2008 | 11:29 AM
Vasichko's Avatar
I have been trying to check this, but still dont know why Im having the 2-3rd issues even when I hold my foot to the floor to 1-2 seconds before moving the shifter.
Oh well, I guess Ill see how it pans out. Pisses me off because Ive been sitting on $3k debating if I want to do stuff and have something break and the Mazda dealer screw me.
Old Feb 8, 2008 | 01:07 PM
Vasichko's Avatar
So should I adjust the pedal away from the floorboard and closer to me?
Old Feb 8, 2008 | 01:50 PM
Brettus's Avatar
Boosted Kiwi
ACT clutches, when newly installed, always have their friction zone(which is very narrow in the first place) quite close to the floor and the pedal free play needs to be adjusted as a result. Otherwise, full disengagement does not happen.
Charles is correct .
I have same setup as you Vashinko and I can tell you it is more finicky than the stock clutch . I ended up getting a SS clutch line and spent some time and effort bleeding the system and adjustiing the pedal to get it right .
I think the SS line did help because with this setup you seem to need all the travel the pedal has to get full disengagement. The stock rubber line will expand under the additional pressure of the ACT setup meaning you need a fraction more pedal travel as some of the travel is used to expand the line.
Old Feb 8, 2008 | 01:59 PM
heyarnold69's Avatar
Rotary wanabee
had the same issue............. Ill be honest ... a tune took it away.. i dont know why ......
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Frosty8
Sep 11, 2015 10:27 PM
GARCIAC951
Sep 10, 2015 07:17 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
