why no oxygen sensor DIY?
Old Feb 7, 2008 | 02:17 PM
Ophitoxaemia's Avatar
dizzy snake pilot
at least, i could not find one for the front sensor, which the dealership said is showing an open signal.
is it because it is so easy no DIY is needed?
Old Feb 7, 2008 | 02:27 PM
nmarz77's Avatar
I'm not sure it gets anymore basic than that. I think I have seen more people have trouble removing the airbox than replacing the 02.
Old Feb 7, 2008 | 02:28 PM
Charles R. Hill's Avatar
Owner of BHR
Yep. Unplug the front sensor connector, which is located on the top of the tranny bellhousing, use a 22MM box-end wrench to remove the sensor, hand-thread new sensor in place, snug up new sensor with the 22MM wrench, and reconnect to the harness.
BTW, the NIssan Murano has the VQ35 in it. Many of the same mods that work on a 350Z also work on a Murano.
Old Feb 7, 2008 | 02:32 PM
Is pretty much like taking out a Bolt with a socket. then put it back with a wrench.
I never did it b4, Trying to do it tomorrow, but thats what it looks like in the Service Manual.
Old Feb 7, 2008 | 02:35 PM
Owner of BHR
Guys, don't make this more complicated than it needs to be. Trust me on the 22mm wrench and if the sensor is hard to loosen, hit it with WD-40 or similar.
Old Feb 7, 2008 | 02:36 PM
how about this
If you know how to add coolant, you will know how to replace the front O2 sensor
Old Feb 7, 2008 | 03:53 PM
dizzy snake pilot
thanks- ill check the service for the location.
ive replaced o2 sensors before on other cars, just checking to see if there were any gotchas on the rx8.
baby due in 6 days- looking forward to having full power available for the trip to the hospital! :D
Old Feb 7, 2008 | 08:34 PM
How about...... If know how to unlock your car with a key?
Old Feb 7, 2008 | 09:53 PM
NgoRX8's Avatar
it's easy to think of what to do, but it might be tough to get the sensor out, and if so you might ruin the threads on the sensor. factory has it on incredibly tight.
Old Feb 7, 2008 | 10:01 PM
Yep and the heat will lock it in place. Stripped threads are common.
Old Aug 13, 2009 | 08:06 PM
reiblh's Avatar
well if it is so esy why cant i find the dumb thing. i just need a pic to show me where it is exactly.
Old Aug 13, 2009 | 08:55 PM
I8U's Avatar
I8U
Cuz you're a dummy...hahaha! It's near the bottom of the exhaust manifold.
Old Aug 14, 2009 | 12:31 PM
reiblh's Avatar
Ok thats fair! No hartbreak here. Under the car, am i looking more at the drivers side or passenger side. When i got underneath a couple nights ago i just didn't see anything. Not really sure what i am looking at on this car. It is my girlfriends and i am learning to help her out.
Old Aug 14, 2009 | 01:11 PM
Look close to the exhaust manifold, you will see a wire attached to it.
you will 100% need a O2 sensor socket to remove it, I forgot the exact size, was it 22mm or hmm, you can get the free load a tool at autozone.
Old Aug 15, 2009 | 12:12 PM
reiblh's Avatar
ok thanks guys i found both sensors. now a new problem. the wire length of the replacement i bought is too short. what the heck. for the 04 rx8 automatic the same sensor acording to autozone fits both pre and post cat. but on the car th pre cat sensor is much longer.
Old Aug 19, 2009 | 04:38 PM
reiblh's Avatar
Well i went ahead a replaced the rear sensor and the engine light went off! Car is doing better. I still get a clicking/poping noise on occasion when accelerating, but not as bad as it was. Any ideas?
Old Aug 19, 2009 | 08:22 PM
hakuna matata!
detonation?
Old Aug 20, 2009 | 12:13 AM
outinnowhere3193's Avatar
outinnowhere3193
clicking...yeah sounds like detonation....someone better stop using that 87 octane and upgrade to a better fuel...or they will be replacing a engine soon.
Old Aug 20, 2009 | 12:19 AM
outinnowhere3193
This is what I did when I had mine stock...in the winter I'd use 87 and not even think about it...during the summer I'd use 89,91,93 start off with the 91 and see how it runs make sure there was no noises...everything good I'd try 89...But all in all if you drive easy you can always get away with the 87 and I mean easy like 3500 and lower and no more then 15% throttle on take off even in the hottest days. The winter feel free to get on her!!!! But at any point you hear a noise when accelerating you need higher octane fuel..you'll notice the increase in power and the noise will go away.
Your driving a rotary...I've been there blown a engine...lol they don't like detonation. Mine was due to in boost when I was too low on fuel caused a lean out..which is basically the same thing as using a low octane. My car bucked hard once and it was done.
Old Sep 2, 2009 | 08:20 AM
reiblh's Avatar
New coil did the trick. clicking gone and much more responsive!
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Nov 24, 2015 01:00 AM
XianUnix
Sep 29, 2015 03:48 PM
