Sushi
02-07-2008, 11:18 AM
Hey guys,
wondering what some of you do with fuel additives, like the ones that clean your fuel system that you put in with a tank of gas. I used to do them on my other cars once every few months, is that recomended? Or is it a waste? Also what are some good ones you guys use. I used to use that Shogun stuff back a few years ago. What are some of the best ones and types to get?
Uncivilizedracer
02-07-2008, 11:44 AM
I Always once a month put the tune up in the clear bottle its good for the fuel and the oil so i figure for the rotory that would be perfect seeing that it mixes anyway !
Silver_Surfer
02-07-2008, 11:45 AM
Lucas Fuel/UCL & BG44 are used here.
Sushi
02-07-2008, 12:04 PM
What brand is that?
And for those suggesting the Lucus Fuel, is that the Injection Cleaner you guys use?
I was looking at this
http://www.autozone.com/selectedZip,29072/initialAction,accessoryProductDetail/initialR,NONAPP10084/shopping/selectZip.htm
Do you just poor a little bit in or the whole bottel, also do you do it on a full tank or half tank of gas?
Huey52
02-07-2008, 12:05 PM
Waste of money. Any quality gasoline already has all the additives needed.
invasion08
02-07-2008, 12:36 PM
Around by me Shell has one of the highest gas prices
Bootleg
02-07-2008, 12:41 PM
i use either seafoam or redline complete fuel system cleaner, which ever i can find. both work great.
Huey52
02-07-2008, 01:19 PM
Perhaps, but at least it's 100% American crude.
here, shell is the same price as the rest.
I mix in some STP with my premix.
Jax_RX8
02-07-2008, 02:58 PM
BG44k is the best for one-time cleanups - most others are snake oils and a waste of money. Some of the very few other cleaners worth considering are Chevron's Techron, Redline SI-1, Gumout Regane, which all use the same main cleaning ingredient.
IMHO, you should add a fuel lube/cleaner to every tank and Lube Control's FP Plus is the best out there.
Lucas UCL is an alternative that is a good lubricant, but just an average cleaner, but would be a good second choice if you are NOT premixing. Redline SI-1 also has a little lubricity, but is mostly a cleaner.
Note that if you are premixing as well (adding 2-cycle oil to gas), then stick with FP Plus (linky below) as Lucas UCL may be causing fuel pump clogging when mixed with other 2-cycle oils.
FP Plus Linky:
http://www.lcdinc.com/
