2007 or 2008 RX8
Old Feb 6, 2008 | 03:00 PM
smackpower's Avatar
2007 or 2008 RX8
I'm thinking about buying a 2007 or 2008 RX8 BUT I'm hearing all these bad things about the 04 and 05. Are the 07 and 08 the same or do they have the same problems? So please get back with me at smackpower@hotmail.com thanks!!
Old Feb 6, 2008 | 03:12 PM
heyarnold69's Avatar
Rotary wanabee
get an 09
Old Feb 6, 2008 | 03:17 PM
New Yorker's Avatar
Just avoid the '04s (or any car in its first-year-of-production).
Old Feb 6, 2008 | 03:31 PM
smackpower's Avatar
The 09's? ummm I don't think it exists does it?
Old Feb 6, 2008 | 03:33 PM
smackpower's Avatar
I just want to know does the 07 and 08 have any problems like the 04's??? Do they have recalls like the 04's did?
Old Feb 6, 2008 | 03:41 PM
chrism's Avatar
Misfit Moderator TnC
https://www.rx8club.com/new-member-forum-197/rx8-faq-new-owners-116484/
Old Feb 6, 2008 | 03:57 PM
tiggerlee's Avatar
May Cause Anal Leakage
uh maybe instead of having folks email you info you should hang out here for awhile educating yourself about the car.
For instance...did you know the 8 has no pistons?
Old Feb 6, 2008 | 03:59 PM
smackpower's Avatar
yes I did
Old Feb 6, 2008 | 04:02 PM
tiggerlee's Avatar
yes I did
Good. that's step one. You have 11 more steps to go. Good Luck.
Old Feb 6, 2008 | 04:06 PM
smackpower's Avatar
I know it has 2 or 3 sparkplugs (can't remember) But are they "special" plugs that costs a fortune?
Old Feb 6, 2008 | 04:07 PM
smackpower's Avatar
thanks for the site!
Old Feb 6, 2008 | 04:45 PM
TopGear8's Avatar
mkuhnracing.com
Get an 07' If you dont mind used then look for an 06'. The 04's are the one's with the most problems.
Old Feb 6, 2008 | 04:48 PM
smackpower's Avatar
What size of rims do most people get on these RX8? Or do you guys keep the 18's in the back and 17's in the front?
Old Feb 6, 2008 | 04:51 PM
JRichter's Avatar
Void Where Prohibited
its 18's all around stock unless its an auto w/o performance package then it's 16's all round
Looks like most people put 18's or 19's for aftermarket with a few 20's
PS: My '05 is flawless...
Old Feb 6, 2008 | 04:54 PM
smackpower's Avatar
I didn't know that. I was looking at a 07 automatic RX8 yesterday and it had 18's in the back and 17's in the front. So what I want is a 07 or 08 RX8. So you would suggest 18's on all 4 wheels? or a different size?
Old Feb 6, 2008 | 04:56 PM
TopGear8's Avatar
mkuhnracing.com
^It's up to you. 19's will probably look better, but you might compromise a little performance because they will be heavier. But not by alot.
Old Feb 6, 2008 | 05:00 PM
JRichter's Avatar
That's sounds wierd. Did they look like aftermarket rims? I'm pretty sure the 8 only comes with the same size rims front and back. If it's an auto with Performance Package then it should have 18's front and back. I would suggest at least getting this package which adds this stuff:
Performance Package AT
* Xenon headlights
* DSC with traction control
* Fog lamps
* Tochigi Fuji Limited Slip Differential
* 18" alloy wheels and 225/45R18 tires
* Larger brakes**
* Sport Tuned suspension**
I would really suggest getting a manual but...
http://www.mazdausa.com/MusaWeb/disp...ehicleCode=RX8
When I get rims this spring I will probably go with 19's.
smackpower's Avatar
If I got 19's would it rub? So if I got a MT RX8, is the standard wheel size 18's in back and 17's in front? or ALL 18's?
Old Feb 6, 2008 | 05:01 PM
smackpower's Avatar
no, it looked stocked
Old Feb 6, 2008 | 05:04 PM
JRichter's Avatar
19's rub? No not if you get the correct offset.
MT RX-8 comes with all 18's. And more power.
smackpower's Avatar
I don't want a automatic
Old Feb 6, 2008 | 05:05 PM
JRichter's Avatar
Check this link and you can see the differences between MT and AUTO rx8
Old Feb 6, 2008 | 05:07 PM
smackpower's Avatar
I HATE automatics. I've seen the specs on the RX8. auto has like 212/hp and MT has like 232/hp i think
Old Feb 6, 2008 | 05:08 PM
smackpower's Avatar
Do you have any messengers like yahoo, msn, etc...
Old Feb 6, 2008 | 05:09 PM
JRichter's Avatar
I'm with you on that. Don't want to pass up the opportunity to enjoy ever aspect of the silky smooth rx-8 drivetrain.
