Will this work with Corksport kit?
Old Feb 5, 2008 | 04:18 PM
ravis217's Avatar
Question Will this work with Corksport kit?
Hi,
I have a pioneer head unit in a double din kit (see attached pic).
Will that whole piece fit into the corksport kit?
I was wanting to keep this headunit b/c it supports USB drives, I just toss music onto a flash drive and the headunit controls everything. I like it alot. Guess that brings up another question...
Can Pioneer AVIC-D3s play music from a USB flash drive?
Thanks,
Travis
Old Feb 5, 2008 | 04:42 PM
WikkedOne's Avatar
Deals on wheels
I'm pretty sure that will fit inside the corksport kit
and i'm pretty sure that D3 does NOT have USB support
i'm not 100% certain on either of these but i'm pretty sure.
Old Feb 5, 2008 | 05:02 PM
Salamanth's Avatar
If you just want music on a USB drive, there is an option that allows you to keep your stock head unit from the RPM store.
You can find it here - http://www.therpmstore.com/product_i...roducts_id=141
As for your original question, I've seen the corksport unit and it should hold that.
A third option for single DIN head units exists, which mounts them above the stock radio so you can retain your stock HVAC controls.
https://www.rx8club.com/showpost.php...57&postcount=1
I'm not sure where he ordered it from.
Hope this helps.
Old Feb 5, 2008 | 06:25 PM
ravis217's Avatar
Thanks for your replies.
I was looking at the usb adapter for the factory head unit, however I plan on putting my amps and subs in so I thought an aftermarket head unit would be best.
RicerX1
Jan 11, 2016 05:59 PM
Epitroch
Epitroch
Oct 24, 2015 12:04 PM
fireishot34
Sep 11, 2015 12:54 PM
Shinka84
Aug 19, 2015 04:55 PM
MolecularConcept
Aug 5, 2015 04:43 PM
