View Full Version : Aftermarket NAV speed sensor wire?
slavearm
02-04-2008, 12:28 AM
What are you guys hooking the speed sensor wires up to? I am about to drop a AVIC-Z2 in my Corksport Kanatechs double din unit.
WikkedOne
02-04-2008, 04:14 AM
Search and you will find.
oh yeah - and I already installed the corksport with the avic Z2 - and i just happen to live near you. if you want some help with your install just send me a PM
slavearm
02-04-2008, 07:18 AM
I looked at your install, but I didn't see a mention of the speed sensor wire. Maybe I am not doing a good search, but I have tried a few and couldn't find what I was looking for. I had no idea you were so close.
Spin9k
02-04-2008, 07:47 AM
Just spill the beans, tell us where you hooked the speed sensor wire! Curious minds are keen to know...
WikkedOne
02-04-2008, 03:10 PM
alright alright... don't twist me arm...
its in the main harness of the HU and it's green and red but there is not a wire in corksport harness to connect to - so you have to cut the main wire and connect it youself. (unless they have changed that which i'm betting they did not.)
oh yeah and for anyone buying the AVIC Z1 or Z2 - make sure you go to www.avic411.com to get bypass instructions - since you have to ground some wires anyways it's easier to do it right out the of box.
Spin9k
02-04-2008, 04:38 PM
its in the main harness of the HU and it's green and red .
Ok, thanks for that and not doubting what you saw, but can you give a bit more help please? Here are diagrams of the head unit connectors etc, and I don't see a R/G wire in either of the C1-01 connectors. Before I go pulling the car apart I want to be sure what I'm looking for. Thanks again.
WikkedOne
02-04-2008, 05:40 PM
Those are diagrams for the dashboard - the VSS wire is in the harness thats connected to the Radio
here is a link to where i got my info http://www.rx8club.com/showthread.php?t=114757
and looking back at the instructions for the corksport kit (http://www.rx8club.com/showpost.php?p=1874137&postcount=69) (3rd to last page and on the top of the last page) I think the corksport harness that plugs into the main harness does have a wire for it.. it's pink - just connect that to your new head unit and you should be good
Spin9k
02-04-2008, 06:19 PM
Thanks I'll give it a try!
MazdaManiac
02-04-2008, 06:28 PM
Has anyone taken a 'scope to that VSS wire to see what the signal looks like?
WikkedOne
02-04-2008, 07:12 PM
all i know is that my Z2 thinks i'm going about 3 to 4 MPH slower than I actually am...
lurch519
02-04-2008, 07:14 PM
did you happen to read the directions that come with the corksport kit????????
MazdaManiac
02-04-2008, 08:13 PM
The OE speedo reads 3 to 4 MPH high.
TheBri
02-05-2008, 12:36 AM
I need to reinstall everything on my 2008 but I remember the install on my 2005 was very easy and everything worked as it should. You just need to look at the wiring diagrams in the Corksport instructions, your HU, and the basic wiring harness for the stock 8 - which is available in many places online. The most "difficult" thing was running a wire back to the reverse light when I did mine which is probably totally unnecessary.
WikkedOne
02-05-2008, 01:01 AM
Bri is right - if you aren't going to add a reverse cam there is no reason to connect the reverse wire.
