View Full Version : Rattling Sunroof
AndyRx8's
01-31-2008, 01:38 PM
My sunroof rattles when it is open. i can't seem to find where the noise is coming from. It is fairly loud and it rattles at any speed. Has anyone else the same problem?
DynamicDookie
01-31-2008, 01:59 PM
its fairly common. there's a service bulletin for the sunroof.
nycgps
01-31-2008, 02:00 PM
This is a well known problem. The solution is to replace the sunroof rack all together.
There is a TSB out for US-Spec RX-8, is there even a Mazda dealer in South Africa ?
Old Rotor
01-31-2008, 03:20 PM
Here is the TSB. Make a copy and bring to your dealer....let us know how it goes...
http://www.finishlineperformance.com/pdf/rx8/bulletin/09-029-06-1651.pdf
AndyRx8's
02-04-2008, 02:30 PM
Thanks for the info. We do have Mazda dealers in all our major towns and cities. The only thing is i dont know if they will cover my problem under warranty because all my Rx8's have been wreaks that i have rebuilt. But I will try anyway. Maybe I will be lucky. Thanks again to all.
VolcomStoneX
02-04-2008, 02:34 PM
i would not do this recall, i did mine and i had to take it back cause it was leaking water, its simply not worth the hassle or risking a leak, they fixed it but the nearest mazda is 25 miles away from my house...those mazda monkeys are a joke
Jedi54
02-04-2008, 02:39 PM
I had the TSB done on my car, fixed the problem for quite some time but now it's squeeking again.
I'm thinking I might just swing by an auto parts store and get some grease.
Razz1
02-04-2008, 10:38 PM
Ja, just lube it.
