A little help guys...
Old Jan 31, 2008 | 04:25 AM
The Ace's Avatar
Greek Power
OK, so I took the big step, and bought the EMU along with the Trust MA-11 harness, A/F option and O2 dongle for my RX8 (4port manual, EUDM). I also have an AEM UEGO wideband installed just before my RP Supercat, which will feed the EMU with AFR data.
As far as I can tell, if I don't decide on doing any <90% ThrotlePct tuning (so I'm sticking with WOT and only >4000rpm), the installation and tuning should be easy, i.e. install the harness, route it inside the cabin, install EMU, connect the A/F option, and then turning it on and start tuning
My two big issues here are:
1) Is the TargetAFR feature enabled/working on the EMU ? I've heard mixed stories.
2) I don't plan on doing anything with timing yet. Should I be doing anything else other than messing with injector maps ?
Also, some help needed with the A/F of my RX8. I am posting the logs I did with sCANanalyser in 2nd, 3rd and 4th gear reading the stock wideband. Seems like my car is running VERY rich. From what I have read here, I should be aiming at 12.8-13 above 4000rpm, correct ? Which maps and values should I be messing with in order to effectively and ONLY trim fuel ? Should I just start with a flat -5% across the board and see what comes of it, or something else ?
Some starter pointers would be more than welcome...
Attached Thumbnails A little help guys...-2nd-gear.jpg   A little help guys...-3rd-gear.jpg   A little help guys...-4th-gear.jpg
amshaw
RX-8 Multimedia/Photo Gallery
10
Aug 26, 2015 08:50 PM
lohsk
Far East/Asia
Jul 15, 2005 10:34 PM
jgoldstein2000
11
Aug 2, 2004 08:15 PM
