scraping sound from engine
Old Jan 30, 2008 | 08:07 PM
heyarnold69's Avatar
Rotary wanabee
so around 3k i sometimes hear a scrapign sound coming from my engine bay ... .anyone?
yes .. oil is perfect.
Old Jan 30, 2008 | 11:16 PM
You have to be more specific than that.
Old Jan 31, 2008 | 01:37 AM
HiTMaNN's Avatar
RX-8s Official Cool Guy
I think it is due to your inferior ***** size. Make sure you check that next time you start your car up
Old Feb 1, 2008 | 10:04 PM
Rotary wanabee
hahahah
ok heres the thing ....
when ever I am around 3k ... coasting .... I hear a scrapign noice .... like a gringinf but high pitched... could my seal be going or the rotor scraping? what?
Old Feb 1, 2008 | 10:07 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
You sure it's not coming from either one of the front corners.....meaning the wheel area?
Old Feb 1, 2008 | 10:08 PM
Get under the car and check everything including the engine bay.
Don't be lazy. Then have someone go with you to pinpoint it if you can't find it.
Old Feb 2, 2008 | 12:27 AM
8 Maniac's Avatar
Senior Member
does it sound like marbles in a blender or can?
Old Feb 2, 2008 | 12:33 AM
marbles usually aren't at that low of an rpm, are they?
(that was my original thought as well)
Old Feb 2, 2008 | 04:12 AM
Startl_Respons's Avatar
Could it be your brake pad squealer indicating time to change pads? You've got to be way more detailed in your description. Try to diagnose it some mroe and get back to us.
BTW, rear pad squealer is very subtle, unlike the front pad squealer. I myself was fooled initially.
Old Feb 2, 2008 | 07:06 AM
Mazurfer's Avatar
That's where I was going with my question posed.
Old Feb 2, 2008 | 07:46 AM
Flashwing's Avatar
3-wheeler
I think I know what the OP is talking about as I have the same experience on my 05. Though I've noticed that the squealing is around approx 50% engine load and it varies by speed/gear. It's only during cruise and takes a very fine adjustment of the pedal to produce it.
Letting off the throttle or increasing it will cause the squealing to go away. I have no leaks and haven't been able to find any loose parts.
It's audible from outside the car as I hear it more with the windows down. I haven't been able to figure out the source of the problem.
The sound is high pitched but not very loud. I only noticed it when I would drive with no music on.
Old Feb 2, 2008 | 10:48 AM
You have to be more specific than that in order for someone to help you locate a sound on the internet.
Old Feb 9, 2008 | 03:09 PM
Rotary wanabee
flashwing described it very well
god its driving me crazy!!!!!!
i'm really just trying ot rule out a faulty oil metering pump or something major
Old Feb 9, 2008 | 04:05 PM
The RX8 will whistle at certain rpms. and I think that is what you are hearing.
Old Feb 9, 2008 | 10:57 PM
What you are describing could be the rear brake pad squealer. I was able to get rid of the sound temporarily by letting off the accelerator as well as downshifting and braking. The rear squealer is only on the passenger side brake pad (the front is also only on the passenger side btw). It's most obvious when you have the passenger side window down.
vapor2
Nov 3, 2020 03:38 PM
Jazzmeson
Aug 6, 2015 04:34 PM
dbarber
Jul 25, 2015 01:34 PM
Bamaham
Jul 23, 2015 08:08 AM
ironj221
Jul 16, 2015 10:16 PM
