View Full Version : Factory HIDs on a NON HID CAR WORKS!!!
BigRed
01-27-2008, 03:35 PM
I just installed OEM ballasts and bulbs and it works! I bought an adapter for the HID bulb on ebay to fit, but it still needed a little work. Ill get pics when I have more time, but this was a great solution for people who want quality ballasts at a low cost! Woot!
BTW, the lenses work fine. There is a clear horizon...
TurboEight
01-27-2008, 03:41 PM
Great tip for people who has the GS, and not wanting crappy cut-offs on the aftermarket conversion kits out there.
dytrd5
01-27-2008, 03:48 PM
I am glad that worked out for you, please post pics when you get a chance and thank you.
BigRed
01-27-2008, 04:12 PM
I will probably do that tonight real quick... From my understanding, it has a clear horizon. Not sure what other people want out of it though.
SayNoToPistons
01-28-2008, 02:08 AM
Clear horizon? What's that?
laythor
01-28-2008, 02:39 AM
rehab facility for celebs outside of LA
Wind Dance
01-28-2008, 03:32 AM
^ lol
WRXtoRX8
01-28-2008, 05:09 AM
local subaru person found these.
http://vvme.com/catalog/list-s-10145-10146.html
lots of the wrx guys including 06-07 which use projector bulbs like our 8's use them with good results. looking at getting a pair for my wrx and 8
lxlxlxl_saki_lxlxlxl
01-28-2008, 04:02 PM
what you need to do this Bigred? how much it costs? how long it takes to install?
BigRed
01-28-2008, 05:17 PM
it varies^ all you need are OEM ballasts, bulbs, bulb converters (d2s to h7 if i recall, or something like that), and some creative thinking.
BigRed
01-28-2008, 05:18 PM
and how long do their ballasts last ?
BigRed
01-28-2008, 09:20 PM
here are the pics. i think my passenger side needs to be adjusted a little bit.
http://i153.photobucket.com/albums/s228/w8nkel/IMG_0077.jpg
http://i153.photobucket.com/albums/s228/w8nkel/IMG_0078.jpg
http://i153.photobucket.com/albums/s228/w8nkel/IMG_0081.jpg
http://i153.photobucket.com/albums/s228/w8nkel/IMG_0082.jpg
http://i153.photobucket.com/albums/s228/w8nkel/IMG_0083.jpg
http://i153.photobucket.com/albums/s228/w8nkel/IMG_0084.jpg
BigRed
sorry they were iphone pics :)
Kris
01-29-2008, 07:54 PM
looks good! now you need matching fogs! I bought LED H11's while i saved up enough to do my HID Fogs. But i couldnt stand the yellowness of the fogs with my HID's.
BigRed
01-29-2008, 08:29 PM
I like the yellow fogs. it also penetrates through fog better :)
Kris
01-29-2008, 09:04 PM
the HID Fogs are great in the fog as well! i have 6000K in the fogs and 6000k in the head lights.
flip702
01-29-2008, 10:29 PM
Nice job... i guess "you've seen the light" now eh? ;)
DOMINION
02-01-2008, 05:20 AM
PM sent
WRXtoRX8
02-01-2008, 08:01 AM
http://vvme.com/faq.jsp#Warranty
14 Months warranty directly with our company !
The ballasts and bulbs comes with 14 Months warranty from all factory defects. If any component fails within warranty period, we will replace the defective component immediately. Contact us with a description of the problem and we will be happy to assist.
what kind of warranty does the oem ones have?
also from someone on the subie forum that has a set informed me they are hella ballasts
-RX8-
02-05-2008, 01:22 AM
do the ballasts plug into the oem wiring? like are the plugs the same?
i'm getting a non-hid 8 and want to add the oem hid's but i want something that looks oem.
02-05-2008, 04:07 PM
+1....
Shadow12one
02-05-2008, 05:35 PM
OEM HID light temp is 4500K. Generally 4500k - 5000k. 6000k will look a bit whiter than OEM with a slight hint of blue, 8000K will look VERY blue, 10,000K - 12,000k is purple (more purple as you go up), etc.
You also loose light output higher up you go. Optimal output ranges between 4500k - 6000k. After 6000k it goes down from there.
Shadow12one
02-05-2008, 05:46 PM
Thats a misconception, yellow lights don't penetrate fog better. You only illuminate the road a bit better because of extra lights at a different angle. But you will get that effect no matter what color lights you have.
I do agree that yellow does work for fog but not in lights. This is how it works. The yellow color removes the blue color in fog (every color in the world comes down to only yellow, red, blue).
The reason why yellow lights don't work is because you are projecting the light outward. It doesn't filter anything out that way. What will work though is if you have glasses with yellow lenses. The yellow lens will filter out the blue pigments before they reach the rods and cones in your eyes. This will "cut" through the fog better than yellow lights.
-RX8-
02-05-2008, 11:10 PM
i was referring to the actual install. i want something plug and play. no splicing, wiring, etc..
Shadow12one
02-06-2008, 01:16 AM
Ah I see
WRXtoRX8
02-06-2008, 06:09 PM
the link I posted is a plug and play. as far as the OP i think he had to purchase something extra from ebay to get it to work.
Eight
08-03-2008, 05:30 AM
I'm planning on doing this mod with oem ballasts and I was wondering how bad the glare is.
I noticed the clear lines on the wall in the pictures, but there seems to be a slight glare right above the cut line, also, in the pictures from the front seemed to be giving off "some" glare.
I'm wondering if its a camera thing or can you pretty much sit infront of the car "at night" and not be blinded as i can do with my halogen.(dont do it literally) Just want to make sure since I've seen "hid conversion kit" converted car with oem projectors like on an integra or GMC suvs and they give of some eye killing glare.
Also wondering how you sealed the bulb to the headlight and the ballast, since with the oem hid assembly theres a plate that covers all the external parts and connections.
04RX8man
08-07-2008, 07:24 PM
Personally I had 8000K and they are alot nicer looking than the OEM but then again i got a conversion kit but i'm glad this is working for ppl....
