RX8 almost killed me
Old Jan 21, 2008 | 08:06 PM
TQ025's Avatar
My rotors are dizzy
So I decided to get my RX8 out the other night because I try to run it during the winter every now and then and as I started driving the gas pedal froze to the floor while I was in 3rd gear and kept increasing speed and rpms. It was sitting on 10k for a good 5 seconds or so while I did everything from pump the gas to press the brake and putting it in neutral until finally i put my foot behind the pedal and pulled it back. Luckily there was noone around and i was far from stops or pedestrians and my engine didnt overheat or explode or wreck. I havent had and problems since then but I'd like to tell my story.
Old Jan 21, 2008 | 08:10 PM
DOMINION's Avatar
I don't buy Kool-Aid
Wow no way. Thank god you where not hurt. How cold was it out?
DarkBrew's Avatar
Extraordinary Engineering
Time to replace the pedal
Old Jan 21, 2008 | 08:11 PM
chancejat's Avatar
Drive it like u stole it!
weird......did you figure out why it got stuck??
Old Jan 21, 2008 | 08:13 PM
Nopstnz's Avatar
dude that is flippin scary! so you were going like 95 or so with no control over the gas?
Old Jan 21, 2008 | 08:14 PM
Rootski's Avatar
DGAF
Clutch it, put it in neutral, turn the key off. Nothin' to it. Why the panic?
Old Jan 21, 2008 | 08:23 PM
staticlag's Avatar
The Professor
^Yes +1
If you ever accelerate out of control, just turn the car off.
Old Jan 21, 2008 | 08:27 PM
Lebren's Avatar
RX8club group buy vendor
The goddam fabric rubs against the petal, I notice! This car which everyone knows is Drive By Wire so it's a light weight petal; needs little pressure to send signal to ecu/throttle. I can totally see this happening, I plan to trim the fabric down by my petal after hearing this!
Old Jan 21, 2008 | 08:29 PM
AmKorp's Avatar
Do you have rubber weather mats in the car? That happened to me once in my Rav4. The rubber mat slipped up behind the pedal and pinched there. All that rubber bunched up behind the pedal wouldn't allow it to come back out. Had to stick my foot under the accelerator and pull it back up. Check to see you don't have the rubber mats riding up behind the pedal.
Old Jan 21, 2008 | 08:34 PM
Mobile's Avatar
If you were topped out in 3rd - you were going fast; you're very lucky! If something like this ever happens again, immediately kill the ignition!
Take your car in and get it checked out as soon as possible.
Old Jan 21, 2008 | 08:50 PM
fugg's Avatar
hm... thanks for your story. I'm gonna see if my rugs all the way in the front now.
Old Jan 21, 2008 | 08:59 PM
DOMINION's Avatar
Question
Are you talking about the floor matts?
Old Jan 21, 2008 | 09:21 PM
Z1NONLY's Avatar
Doesn't the steering wheel lock when you turn the key "off"?
Old Jan 21, 2008 | 10:59 PM
if u turn it too quick yeah.
it sound like he was going a straight anyway, so just turn it off and Brake. no need to panic
Old Jan 21, 2008 | 11:08 PM
Looks like you won't have to worry about carbon for awhile.
Maybe a week, then back to redline a day.
Old Jan 22, 2008 | 01:51 AM
Squidward's Avatar
Bottom feeder
dude that's freaking scary.. you know the suggestion about killing the ignition is a good one, but when you're in that situation, I doubt everyone can remain calm and think of the best way out. I mean you're seconds into a possible disaster, being able to remain calm and coming up with a solution is not exactly a skill many people have.
I'm glad you safely got out of that situation...
Old Jan 22, 2008 | 02:02 AM
Zephyr Words's Avatar
Lets go Caps!
Also remember you'll need to press on the brakes very hard when the car is "off" to get the same effect as tapping on them normally.
I think he did alright people - he said his process took about 5 seconds. Hard to believe the pedal froze to the floor though.
Old Jan 22, 2008 | 03:09 AM
DOMINION's Avatar
^Its also hard to believe this car can burn to the ground in seconds right? Well it can.
Old Jan 22, 2008 | 04:06 AM
TrochoidMagic's Avatar
is adjusting valve lash
turning the car off...then back on so he has power to turn the steering wheel. and all out of gear of course. there will be no vacuum available to assist in braking force as well.
but still good thing that he managed his way out.
i never used/bought any more of those plastic floor mats after my first car. being this "pedal stuck under mat" incident occured to me as well. aftermarket mats are always in the way and worth more out of the car then in.
have the pedal linkages inspected for any bindings and rust and such...
Old Jan 22, 2008 | 08:39 AM
StealthTL's Avatar
Metatron
Brakes still work fine without engine vacuum, steering is also easy without the power assist.
The steering wheel won't lock just because you turn the ignition off, it don't work like that. You would need to pull the key completely out, and even then you can steer to a straight stop without it locking.
S
Old Jan 22, 2008 | 09:23 AM
Rems31's Avatar
S
what about those that have the credit card key and dont have to put the key in?
Old Jan 22, 2008 | 09:47 AM
Socket7's Avatar
ಠ_ಠ
I was always taught to never turn a car off while it's moving. To many things rely on engine power like traction control, brakes, steering wheel locks, power steering, etc. etc. Yeah, you shouldn't have a problem turning the engine off, but personally I'd rather come to a screeching halt then kill the engine, rather then the other way around.
I'm Glad your safe. That's scary as all hell.
Old Jan 22, 2008 | 10:07 AM
Mobile's Avatar
There is still a *** where the key normally sits for you to turn.
Old Jan 22, 2008 | 10:09 AM
Rems31's Avatar
yea I know but Stealth said you have to pull the key out of the ignition...so how does it work in that case
Old Jan 22, 2008 | 10:48 AM
New Yorker's Avatar
Originally Posted by TQ025
I havent had and problems since then but I'd like to spread my story as a warning.
A "warning," huh? So what are you saying, exactly? That the RX-8 has a design flaw that can cause unintended acceleration? The title you gave this thread - "RX8 almost killed me" - certainly suggests that. That's a fairly serious charge to make and, frankly, I suspect it's not true.
If that happened to me, I'd have to completely, positively, absolutely rule out driver error (i.e. an unsecured front mat) before starting a thread scaring people into thinking the RX-8's accelerator will suddenly "freeze to the floor." I'm not saying there isn't a design flaw, just that it's highly unlikely. (And when you start a thread about something this serious, you might give it a more appropriate, less sensational title. Something like "my accelerator stuck.")
