View Full Version : Need advice on Volks Racing GT-AV Rims Specs
Tremoryeo 01-20-2008, 11:41 AM Hi guys,
I am interested in getting this 18" rims. However, I am not sure what are the specs that can fit my car. I have the intention to change my brakes in future.
1) What's the width of the rims I should go for? 8? 8 1/2? or 9? Or should I go for offset?
2) How "deep" can the dish go? 31 mm? 41 mm?
3) What tyres is the most quietest and offer reasonable grip on wet roads?
Any advice will be appreciated!!
dannobre 01-20-2008, 11:59 AM You have a lot of variables that preclude giving you much advice.
Some brake kits won't fit certain wheels...and depending on the wheel style, offset and the width will determine what lip or "dish" you can get.
FYI if the offset is right...you can cram in up to 10" wheels/275 tires on all four corners.....
As for tires....what are you looking for...performance..all-seasons???
Do a search and pin down a few variables first......and then we can give you some better advice
Im_DANomite 01-20-2008, 12:33 PM staggered setup:
18x8 +22 (44mm lip, will fit big brakes)
18x9 +31 (69mm lip, low disk type)
non-staggered:
18x8 +22 all around (will fit big brakes up front)
or
18x9 +29 all around (will fit big brakes, 50mm lip)
18x9 +30 all around (will NOT fit big brakes, 63mm lip)
18x9 +31 all around (will NOT fit big brakes, 69mm lip)
coupe07 01-20-2008, 01:33 PM staggered setup:
non-staggered:
or
all ur recommendations will rub fenders and wheels will pop out from fenders..
dannobre 01-20-2008, 08:43 PM staggered setup:
non-staggered:
or
I think you need to relook at these #'s........not going to happen ( might fit on a 350Z though :) )
Tremoryeo 01-21-2008, 11:18 AM all ur recommendations will rub fenders and wheels will pop out from fenders..
Coupe07,
Do you have any recommendations?
Im_DANomite 01-21-2008, 05:52 PM they will not stick out, depending on how low the car is, you MIGHT have to modify the fenders. but these sizes will work.
Im_DANomite 01-21-2008, 05:59 PM i am running 18x9.5 +38 all around with 255/35R18 all around with JIC coilovers. no rubbing at all. with 9" wide wheel you can go as low as +30. INGS runs 19x8.5 +22 offset with fender modification, so an 8" wide wheel will be perfectly fine. the sizes i gave you are the most aggressive you can get for the RX8, of course you can be a little more conservative with the offset.
my volks are 19x9.5 +36 and it's perfect. the fronts are 19x8.5 +34 and it's a little too conservative for me...i should've went with a +29
Tremoryeo 01-24-2008, 05:56 AM Can anyone else provide any advice on this, especially those in SG? It would also be good if u can direct me to a expert. Need to know the specs b4 I can place my order. Thanks!
coupe07 01-24-2008, 10:48 AM Can anyone else provide any advice on this, especially those in SG? It would also be good if u can direct me to a expert. Need to know the specs b4 I can place my order. Thanks!
go to the meetup or come outside MG... u will see many patterns. some stagger, some play deep dish... some play all round same size, some buy taiwan rims then regret becos dun cater to BBK.
if u r interested, tan280 has a set of WORK VF-KS rims for sale. Very nice deep dish, and can cater for ENDLESS or GREX 6 potters...
Maybe u can get him to show u a pic or 2... selling cheaply too i tink..
Swerve76 01-24-2008, 11:22 PM go to the meetup or come outside MG... u will see many patterns. some stagger, some play deep dish... some play all round same size, some buy taiwan rims then regret becos dun cater to BBK.
Haiz I concur. Me was one of those idiots who bought bling bling taiwan rims....but cannot fit bbk.
Sianz.
BUT I got a good deal on some Volks GT7's which now can fit bbk's muhahahahahahahahahaha.
Now to strike 4D and buy me a set ;)
