please recommend me a helmet (already searched)
Old Jan 18, 2008 | 03:55 PM
trustbuddy's Avatar
can anyone link me to a website that sells decent racing helmets. SA95.
i've searched here and looked up google. Just not sure what i exactly need.
Track noob here~
Old Jan 18, 2008 | 04:01 PM
staticlag's Avatar
The Professor
http://www.saferacer.com/g-force-pro...?productid=934
Old Jan 18, 2008 | 04:04 PM
CosmosMpower's Avatar
1935 lbs. FTW!
I wouldn't get a SA 95, that rating is going to be out of date soon. If you're on a budget at least get SA2000 or if you just autocross just get a M2000/M2005 helmet. I got a Pyrotect closed face on Ebay for about 150. I think I'm going to ugprade to an Arai or OMP soon though.
Old Jan 18, 2008 | 04:16 PM
trustbuddy's Avatar
ok...thanks for the quick responses.
how do i calculate what size helmet i need?
Old Jan 18, 2008 | 04:20 PM
1935 lbs. FTW!
There should be a sizing chart on one of the retailer websites. Check saferacer.com, apexperformance.net etc.
Old Jan 18, 2008 | 04:21 PM
mwood's Avatar
That is a tough question. It is easy enough to measure your "hat size", but different brand helmets fit very differently, for a given size, so you might need a different size in, say, a Bell than you would in a Arai, for example.
In the best case, you should try on any helmet you're interested in before buying...and leave it on for at least 10-15 minutes. What can at first seem like a minor "pressure point" can end up being a major headache (literally) after 20 minutes or more on track.
More than anything else, fit is key when choosing a helmet, both for comfort and for safety reasons!!!
Old Jan 21, 2008 | 03:25 PM
chkrd_flag's Avatar
+1000
Fit is the #1 priority... and don't skimp - the most expensive helmet is still a lot cheaper than a broken cranium!
Old Jan 21, 2008 | 06:22 PM
Galen Darkmoon's Avatar
I don't remember
Find a big motorcycle store. The one we went to had over a hundred helmets to try on so the misses took her time and found a really nice bell class M2005.
Old Jan 21, 2008 | 06:28 PM
mwood's Avatar
Before buying a M rated helmet, I'd check and make sure none of the groups you plan to run with require, or are considering requiring, SA helmets. Many of the HPDE or open track groups no longer accept M helmets...
But, as was said above, if you are just running autocross, M helmets can be had for bargain bin prices...the one I use for autocross was around $50, is light and also full Snell certified, of course...once a helmet gets past the Snell standards, you really are just paying for bells and whistles (removeable liner, vents etc.), prettier graphics, lighter weight and name brand...you aren't picking up any additional "safety" that is easily quantified...
Old Jan 21, 2008 | 09:10 PM
Scrapin 240's Avatar
Arai of Bell, if you have the cash
Old Jan 22, 2008 | 01:39 AM
I don't remember
The misses only plans to do a little auto-x and maybe a couple fun runs on the heartland track in topeka. Both only require the M class. She picked up the new Bell Apex "Tagged"
Old Jan 22, 2008 | 09:13 AM
altiain's Avatar
Sparky!
+1000 more.
Already said it in another thread, but I'll copy & paste it here:
For track days I would recommend an SA-rated helmet over an M-rated helmet (click here to learn the difference between SA and M ratings) due to the extra flammability and multi-impact requirements.
Beyond an SA rating, more expensive helmets tend to be lighter (which is nice during a 20-minute track session), offer better venting, and additional features like removable/washable liners. I would personally recommend getting the best helmet you can afford.
I would encourage you to try on helmets from several different manufacturers to ensure yourself of a good fit. Different brands fit differently. When I bought my current helmet, I was leanining towards a Bell M3 Pro. While Bell makes excellent helmets, they don't fit my head shape very comfortably. After trying several on, I ended up with a Simpson Super Bandit instead. Pressure points may not be critical to you if you're looking for an autocross helmet where you're only wearing it for a minute or two at a time, but for twenty minute track sessions helmet fit can have a big impact on your concentration levels.
Also make sure to size your helmet properly. To do its job properly in the event of an accident, it should fit snugly. If the helmet moves when you nod your head, it is too big.
Old Jan 22, 2008 | 10:11 AM
chkrd_flag's Avatar
A two hour stint with so much a a slight pressure point issue sucks rocks
lol
Old Jan 22, 2008 | 10:29 AM
staticlag's Avatar
The Professor
Just get a neck protector, your helmet rests on it so its no problem to wear it for long periods.
I haven't had any problems with visibility at both autox and track days.
Old Jan 22, 2008 | 10:53 AM
altiain's Avatar
Sparky!
A neck protector isn't going to do anything to alleviate pressure points if the helmet doesn't fit the shape of your head properly.
Old Jan 22, 2008 | 12:42 PM
mwood's Avatar
My understanding (which is minimal, like it is on most subjects) of the differences between the SA and M standards are, as Iain said, greater fire retardation in the SA and a different set of impacts used in the actual testing, with the SA helmets receiving more "concentrated" impacts (think of hitting a roll cage bar, hopefully well padded!) while the motorcycle helmets are tested more on broader impact (think of hitting the pavement).
Regardless, just because of the trend to requiring SA for lapping or HPDE groups, I wouldn't consider a M, if I planned on doing mostly track events.
Old Jan 22, 2008 | 12:55 PM
buy the best you can afford, WRT to safety equipment being cheap doen't pay off in the long run ...
Old Jan 22, 2008 | 11:12 PM
OnRails's Avatar
I was reading through the link above and uncovered this gem:
"The Foundation recommends that if you are participating in an activity that requires that you wear a helmet, that you avoid hitting stuff with your head."
Brilliant!
Old Jan 22, 2008 | 11:56 PM
I don't remember
Paying for a SA rated helmet is a waste if not needed. PLZ read the post it was about fit.
Old Jan 23, 2008 | 12:23 AM
Astral's Avatar
Purveyor of fine bass
Trying on the helmet in the store is key! It's worth the price premium.
Some brands like Pyrotect and G-Force have dealer listings online. Find a local dealer.
I tried on three different helmets, all sized Large, and they all fit differently! And in fact the one that I probably would've ordered online did not fit my forehead well!
Old Jan 23, 2008 | 09:05 AM
altiain's Avatar
Sparky!
Actually, the original post was about helmets in general. And buying a flame retardant helmet rated for multiple impacts is obviously a waste when driving a gasoline-powered, enclosed car.
As a good friend of mine likes to say, "If you don't think you need a good helmet, you're probably right."
Old Jan 24, 2008 | 12:00 PM
Cito's Avatar
Racehelmet.com
This is a company that is local to me. Murray (I think is his name) is a knowledgeable guy who will give you the information and answers you need. Toll-free call. His prices are fair and he sets them at the "lowest advertisable price."
Personally, I would go with the highest rated and nicest helmet you can afford. It is a little known fact, but your brain is inside of your head. Even in autox, very bad things can happen.
Old Jan 24, 2008 | 12:05 PM
mwood's Avatar
Can anyone point to any data that supports the idea that higher priced helmets are "safer", given the same shell material? I've always been led to believe that once a helmet of normal construction passes Snell, that the only real differences are the features, weight and name...but, I'm sure that could be wrong.
Of course, once you get into exotic CF weaves and stuff, I'm sure the impact characteristics change significantly....
Old Jan 25, 2008 | 12:20 AM
Senna's Avatar
Merchant Of Pace
Try Helmetcity.com. Good service and prices. I just got a Bell GTX that I'm real pleased with. Don't go cheap on safety equipment.
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Nov 24, 2015 01:00 AM
Michael Bryant
Oct 12, 2015 03:07 PM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
Evan Gray
Sep 26, 2015 12:30 PM
