4th gear trouble
Old Jan 10, 2008 | 04:30 PM
the_josher's Avatar
4th gear trouble
My problem is when im downshifting or just shifting into fourth gear in high rpms like 4 - and above, I hear this grinding noise whenever i shift. It isn't a smooth shift.
I've tested it and it never fails to grind, I'm not forcing it in at all, it use to shift smoothly and for some reason now its making these uncomfortable noises.
It hurts my heart to hear this and I'm no mechanic so I don't know where to start in order to fix this.
Just hoping for some advice and ways to fix this. thanks
Old Jan 10, 2008 | 04:34 PM
mysql101's Avatar
my car is at the dealership right now for this exact reason. 3-4 upshift grinds when 4k rpm or higher.
Old Jan 10, 2008 | 07:31 PM
trans shop or stealer ... this is only a DIY for the hardcore home mechanic
Old Jan 10, 2008 | 08:32 PM
the_josher's Avatar
does it fall under warranty? and if not how much is it
Old Jan 12, 2008 | 12:54 AM
the_josher's Avatar
any update on this yet
Old Jan 12, 2008 | 01:05 AM
bose's Avatar
Reginald P. Billingsly
This is begining to happen to me, does anyone think the dealer will make a big deal about my intake and exhaust? I don't think they could relate the two just wanted others opinions?
Old Jan 12, 2008 | 01:47 AM
06carbon8's Avatar
same problem here. unfortunately i have an act clutch/pressure plate/flywheel. no warranty for me.
Old Jan 12, 2008 | 02:17 AM
mmats69's Avatar
93.5 octane
Yes they will give you hell no doubt about it. They will try to say you have been abusing the car. Same thing happened to me but nothing they can really do but try to intimidate you.
I've had this problem as well. Ended up with a new tranny after all was said and done.
Old Jan 12, 2008 | 01:14 PM
bose's Avatar
So just basically stand my ground? I've only had the car for 2500 miles got it in sept. and I have kept up on everything perfectly, run royal purple in the trans and diff. Though I wanna switch to redline my buddies wrx's shift like silk, before I take it in to see if it helps.
Old Jan 15, 2008 | 04:51 PM
gangster8's Avatar
i have the same problem except from 1 to 2nd gear. its your synchro or your transmission, i just took my car to the dealer today with 55k miles on it, and they are giving me a new transmission woo hoo you have a 60,000 mile powertrain warranty, use it!
Old Jan 15, 2008 | 07:43 PM
Romancer's Avatar
I had the same exact problem with my 8. When I took it to the dealer, they claimed I was making it up because they couldn't duplicate the problem.
God Bless,
theblinkof
Oct 4, 2023 05:24 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
WranglerFan
Nov 5, 2017 09:35 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
