HKS Single-sided exhaust picture (NOT on the car)
Old Jan 10, 2008 | 11:02 AM
Yan's Avatar
Yan
As the title says, please!
PS: I saw numerous "on-car" pictures here, but none of the actual system.
Thank you!
Old Jan 10, 2008 | 12:03 PM
dillsrotary's Avatar
jersey fresh
Attached Thumbnails HKS Single-sided exhaust picture (NOT on the car)-exhaust.jpg
Old Jan 10, 2008 | 12:09 PM
Yan's Avatar
Yan
Thanks Dillsrotary!
Others can post too!
Old Jan 10, 2008 | 01:54 PM
scsi's Avatar
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/hks-hi-power-exhaust-123908/
Old Jan 11, 2008 | 11:03 AM
Yan's Avatar
Yan
THANKS!
Old Jan 11, 2008 | 05:32 PM
some very old pix of mine
Old Jan 11, 2008 | 06:08 PM
Yan's Avatar
Yan
Thanx!!!
These 2 underside views really helped me!
I think my exhaust setup gonna be this:
Racing Beat header (if it come out; if not ExoticSpeed)
Racing Beat race midpipe
HKS Hi-Power Exhaust
Yummy! (and loud)
Old Jan 11, 2008 | 06:15 PM
mysql101's Avatar
Originally Posted by Yan
Yummy! (and loud)
Dude, loud doesn't even begin to describe it...
Attached Thumbnails HKS Single-sided exhaust picture (NOT on the car)-p1000815.jpg
Old Jan 11, 2008 | 06:35 PM
here's my setup:
HKS Racing Suction Intake
HKS Metal Catalyzer Resonated Mid Pipe
HKS Single Side High Power Exhaust
Video:
http://www.youtube.com/watch?v=M7y6TifMBWw
Old Jan 11, 2008 | 07:00 PM
Yan's Avatar
Yan
here's my setup:
Video:
Thanx!
I forgot to tell you I saw the videos of your car so often... You are like my hero! HKS-everything, TE37's... may I ask what suspension setup are you running?
Old Jan 11, 2008 | 07:04 PM
BigRed's Avatar
w8nkel
HKS^ lol
Old Jan 11, 2008 | 11:16 PM
Originally Posted by BigRed
HKS^ lol
hahaha WAAP WAAAP WAAAAAP HKS Hipermax II's!
Old Jan 12, 2008 | 12:00 AM
c'mon Yan as if there was ANY doubt that XdeedubbX would have anything BUT an HKS suspension system.
I've actually driven Xdeedubbx's car and the hipermax coilovers feel SWEEEEET!
Old Jan 12, 2008 | 10:56 AM
Yan's Avatar
Yan
Ahaha, sorry guy's I was kinda slow on this one!
Personally, I was more leaning toward TEIN Mono Flex for these 4 reasons:
- Stiffer than most coil-overs on the market (only top-of-the-line Zeal's are 1kg stiffer in the rear).
- Monotube for superior damping (I have tried both twin and mono on my Pro and the mono's are far superior, IMO)
- 10kg/7kg make it the same stiffness as the JIC FLT-A2 Hard and 200$ cheaper
- Damping are supposed to be better than most other Japan-made coil-overs
Old Jan 12, 2008 | 11:09 AM
thanks jedimaster...
Old Jan 12, 2008 | 12:10 PM
yan: you going to track your car? You're talking about a REALLY stiff ride there...
Old Jan 12, 2008 | 01:28 PM
Yan's Avatar
Yan
Ahaha, don't worry! I used to a stiff ride.
I have a 03 Protegé LX (returning back to stock to buy a RX-8) with the following suspension:
- Custom-made JIC FLT-A2RS with 9kg/7kg (About 500/400lb.-inch, ~100lbs less than World Challenge Protegé's)
- AWR front and rear spherical-bearing anti-roll bar links
- AWR 21.5mm adjustable rear sway-bar
- AWR rear trailing arms
- Cusco front strut-bar
- Custom alignement specs (very agressive for a daily-driver lol)
So, the LX being the lightest 2.0L Protegé here in Canada, combined with that stuff, needless to say that my car was... lively!
As a comparaison, my Pro weight about 1194kg and have 4 struts, meaning the relation between spring rate and actual rate is direct. The RX-8 is 1389kg and have a wishbone/multilink setup, which necessitate higher spring rate to acheive comparable results due to the "lever" effect of a wishbone/multilink setup.
So, to resume lol, I actually think tha the 8 will feel softer than my Pro!
PS: Guys, what anti-roll bars are your favorite? I'm torn betwwen the Agency Power setup and the Mazdaspeed set... Thread here:
https://www.rx8club.com/showthread.p...21#post2238421
Old Jan 13, 2008 | 12:06 PM
superdon2's Avatar
Now watch me yuuuuaaaaaa!
isn't it safer that the single-sided exhaust is pointed at the opposite direction as the fueling port..?
Mr.Durden
Aug 12, 2015 02:21 PM
N0P1st0ns
Jul 30, 2015 09:45 AM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
