Rx8 F***** Up Help
I WENT OUT OF TOWN AND WHEN I CAME BACK THE RX8 BARLEY STARTED AND WHEN IT DID THE OIL LIGHT CAME ON THEN I CALLED THE DEALER SHIP AND THEY
TOLD ME THAT THE WARRANTY ON IT IS GONE AND THEY ALSO TOLD ME THAT THE PROBLEM WAS THAT MY AIR MANIFOLD HAD A LEAK AND THAT WAS CASUING THE OIL TO FOAM UP DOSE ANYONE KNOW HOW MUCH THIS WOULD COST TO GET FIXED
It does not sound like you have a problem at all . You went away for "a while" - any more than a week or two and your battery will be down so it won't crank over very well and will be hard to start . The oil light comes on when the level is down - top it up . The foaming oil is a common problem - type in "dip stick foam" in search for that .
^^^ thanks man i mean i really dont wont to get rid of the car but how the service man was talking i should of sold it by now he was saying that the car probbaly had a leak in the air manifold and that it probally mixed oil and water
ahhahahaah im located in louisville ky but that was the dealer that really no one goes to the reason y i called them is because my normal dealer is busy as hell and they cant take my car in untill thursday and im gonna have to wait till then
http://www.finishlineperformance.com.../pdf/ad-18.pdf
^^Read,Smile,Get your car fixed! I have a super early production model 06/03 and mine still covered so IM SURE yours is....
Yes call them tell them DAMNIT ITS UNDER WARRANTY! If you read the SSP letter it tells you what your entitled too and what # too call if you have any more questions...If you don't feel you can handle it show your parents that letter and tell them to handle it.....I would just call mazda and tell them about how the dealership you went too diagnosed your car over the phone...without looking at it and then went on to say your not covered....seems kinda shitty to me
Powertrain Warranty Parts List
Below are the powertrain components covered under the Powertrain Limited
Warranty:
Engine
Cylinder Block, Cylinder Head, and All Internal Lubricated Parts (Piston engines)
Rotor Housing and All Internal Lubricated Parts (Rotary engines)
Timing gears
Timing chain/belt and tensioner
Timing chain/belt front cover and gaskets
Flywheel
Valve Covers and Gaskets
Oil Pan
Oil Pump
Intake Manifold and Gaskets
Exhaust Manifold and Gaskets
Engine Mounts
Turbocharger Housing and All Internal Parts
Supercharger Housing and All Internal Parts
Water Pump and Gaskets
Thermostat and Gaskets
Fuel Pump
Seals and Gaskets
Warranty:
Engine
Timing gears
Flywheel
Oil Pan
Oil Pump
Engine Mounts
Fuel Pump
Seals and Gaskets
Top off the oil & don't let it get low again. Don't call that dealership again, ever. Call the other one and set an appointment to have it checked out. But the safest bet is that you need to keep a closer eye on your oil level to avoid the oil light coming on. Good luck, and for the love of all things unholy - turn off you caps lock key!
i didnt start my car for 3 days and the oil foamed up i was told cold weather is to blame. oil change and it was fine then i didnt drive for 2 days and i started to see foam again.so i have no freakin clue
dmc27 i did its not on no more
and i raelly appriciate the help you guys this probbaly saved me alot of money becuae i was really ready to go take the car to the dealer and let them fix the manifold
and dude thanks for the warranty papers
I think your cars have RABIES!!! Hey man no problem, the reason why I know that is because I bought my car yesterday and took it to the dealer today to make sure it had all recalls and such...and they told me I had an extended warranty :-) :-)
