Cold Weather Starts
Old Jan 3, 2008 | 10:17 AM
robfernando's Avatar
Question Cold Weather Starts
OK - So it's 5 degrees F outside, windchill has it at -10 F. I crank for about 3 seconds, it starts fine! HOWEVER, when I take my foot off the clutch, the RPMs go nuts, kinda like a rough idle between 3000 RPM and 1500 RPM, it's like it goes to 3000, says ok, too fast and then reduces it to 1500 and goes, whoops, too slow!
Once I press the clutch back in, the engine is smooth again. Ultimately I had to keep my foot on the clutch for 2 mins before I could let it warm up normally.
Any ideas?
Old Jan 3, 2008 | 10:32 AM
ZoomZoomH's Avatar
Mulligan User
actually I think the 3000rpm jump is 'normal' for very cold startups
you should let the car warm up as it wants to.
Old Jan 3, 2008 | 10:36 AM
jasmin's Avatar
Any ideas?
I have the same problem...anyone know the reason of that. I called the dealer and he said this is maybe a switch problem on the transmission....
Old Jan 3, 2008 | 11:34 AM
RX8KRIS's Avatar
Speed, I Am Speed!
I have the same problem... what oil are you all running in your trans?
Old Jan 3, 2008 | 11:47 AM
jasmin's Avatar
I don't know. I bought the car 5 month ago and I do not add trans oil.
Old Jan 3, 2008 | 11:52 AM
RotaryP7's Avatar
Seriously.. FML..
It's freaking cold now.. 53F..
In the morning my 8 said it was at 39F!
btw, this is freezing in Miami..
Old Jan 3, 2008 | 12:03 PM
RX8KRIS's Avatar
Speed, I Am Speed!
I put Redline Shockproof heavy gear oil in my trans and its a pretty thick oil so I figured the idle jumping on cold days came from the trans trying to sling the thicker really cold oil thru out the trans but I'm probably wrong.
Old Jan 3, 2008 | 12:06 PM
RojoOcho's Avatar
Greensboro's Finest
Mine does the RPM jump too. I think this is intentional. I just let it do it's thing before I drive.
Old Jan 3, 2008 | 12:10 PM
secret8gent's Avatar
the enemy in the mirror
haha, when i started up my car this morning (it was 6F out) i thought to myself:
I wonder if i'll see any 'cold startup' threads on the club.
and lo, I did.
it's 'normal' for an rx-8 as far as i know. let it do what it wants. Mine struggled for an extra 1/2 second or so (new battery but original starter '04) while starting but turned over and then revved itself to almost 4 before steadily dropping to 1.5k and holding there until it was warm enough to be movable.
two cents for you, 1 post for me.
Old Jan 3, 2008 | 12:37 PM
Apostle's Avatar
Cupcake Master
Every car i have had will have a high idle on cold mornings. once it warms up enough (not enough to get the heater working) it automatically drops to normal idle.
dont worry about it, as long as it doesnt stay that way or jump above 3k, you should be fine
Old Jan 3, 2008 | 01:29 PM
Duke15's Avatar
2006 Velocity Red Mica
Mine cranks for about 5 seconds before actually starting, then jumps to 3 - 4K RPM. (approx 20 degrees F) I had the dealership look at it and they said I already have the heavy duty battery and it was normal - for whatever that is worth.
Old Jan 3, 2008 | 01:33 PM
Leesha's Avatar
View at your own Risk :)
It's -17C today...
I have an AT and it does the same thing until its warm. Kind of hesitates a bit then speeds up... Has a mind of its own I guess...
Old Jan 3, 2008 | 02:48 PM
SilverStreak's Avatar
I agree, you shouldn't worry. Mine has done the up to 4K then gradual decrease, it has also done the rev up and down between 1.5 to 3K. I haven't really identified a pattern to how or why but it always starts and once warmed up performs fine. It is possible that at extremely low temps the transmission neutral switch or the clutch switch may be sticking a little and causing the idle to "hunt" but that's purely theory on my part. As long as it starts and the idle settles in eventually all is right with the world.
Old Jan 3, 2008 | 03:07 PM
enforcer's Avatar
Originally Posted by Leesha
It's -17C today...
I will never complain when it gets down to 4C in Brisbane again!
Old Jan 3, 2008 | 03:08 PM
RX8 dood's Avatar
Most newer cars do this....Its to get the fluids moving and everything warmed asap
Old Jan 3, 2008 | 03:27 PM
2tone's Avatar
The RX-8 is missed
i concur. the *up-to-3k* appears to be normal for super cold weather. it freaked me out at first too. i do not however, have that erratic idle - it's just up to 2500 or so, then a gradual decrease to normal. i let it sit until at least at or below 1500 before i drive off.
Old Jan 3, 2008 | 04:10 PM
RojoOcho's Avatar
Greensboro's Finest
Warmed Up Renesis = Happy Renesis!
Old Jan 5, 2008 | 04:10 PM
hagar852's Avatar
This also has happened to me and I captured it on my phone. If I get a chance to get the video off of it I can post it.
Old Jan 5, 2008 | 04:14 PM
Jeison's Avatar
remind me to post a pic from my temp gauge when its -40C not including windchill.. those are fun days.. go outside and hope :p
Old Jan 5, 2008 | 05:18 PM
04RX8man's Avatar
Rotary Powered Countryboy
Well i parked my 8 this winter but i remember last year that it did do that. and i noticed when you release the clutch the rpm's drop fast almost like it could stall.....seems normal to me never had any problems
Old Jan 5, 2008 | 05:42 PM
TrochoidMagic's Avatar
is adjusting valve lash
if you see temps that low in the area you live in, its wise to stick with the oil viscosity recommended for that environment. so its ok to use 5w20 and stick with it for that temp.
it should be normal. and don't be scared by it... as there are no ways to bypass this as our cars run on a drive-by-wire system without an iacv. there really is no way to alter it as the throttle now adjusts for warm-up idle speed.
let it do its job... if its not normal, then a cel will render it otherwise.
Old Jan 5, 2008 | 05:45 PM
btw, i see start-up idle near or above 2k. i've seen 50degrees or lower here on mornings. and i usually drive when the oil pressure sets around 50psi and when the water temp starts moving above 120...
then again, i have a gauge...
Old Jan 24, 2008 | 09:00 AM
exarkun's Avatar
Mine has done the same exact thing since I've had it (3 winters now.) I just always assumed it was normal.
However, it's been REALLY cold lately. (-12 F with no wind chill this morning)
Last Friday, after leaving work, I started it up, it did the normal rev thing till warm. However, once I pulled out of the parking lot, it flashed a CEL. I went to autozone and got the code pulled and it was this:
P0850 Neutral switch input circuit problem ON 2 CCM ´ (See DTC
P0850 )
I have no idea what that means...The next day though, the CEL went away by itself. But, yesterday, it was extremely cold again, and the code came back a little bit after starting it up. Anyone know what this code means? It seems to be related to the cold weather...
Old Mar 19, 2008 | 07:02 PM
stuberncustoms's Avatar
P0850
Engine code P0850 is a park/neutral switch input circuit error. I actually have that on right now. I have an appointment with the dealership to check it out because as of yesterday my 05 Shinka started idling erratically as previously stated and this code popped up. It was about 60 degrees when it happened so nothing to do with the cold. it pulsates from 1000 to about 2500 back and forth until i push in the clutch.
Old Mar 19, 2008 | 09:47 PM
04RX8man's Avatar
Mine does it also...I think it is normal I just slowly let out the clutch then the rpm's drop slowly then once the clutch is completely they climp up to abut 3k and finally fall to 1k when warmeed up enough to move...
Jesus Martinez
44
May 6, 2025 08:09 AM
Redheddude222
Aug 24, 2015 09:14 AM
Modern2Strokez
Aug 16, 2015 01:07 AM
dbarber
Jul 25, 2015 01:34 PM
