My Engine Light Came On Reading " System Too Lean "
Old Jan 2, 2008 | 08:22 PM
dpulse2930's Avatar
anyone know what the problem can be?
i did take it to local shop , and they say oxgen sensor..? or air and fuel sensor..?
they estimated $125 + $75 labor for oxygen sensor
and 325 + 75 labor for air and fuel sensor
to be replaced...
i asked, so do i have to replace both? and shop sais.. its better to..
I think its BS... trying to save money...
Please help ..
any one ever had system too lean on engine light?
Old Jan 2, 2008 | 08:24 PM
VolcomStoneX's Avatar
Hi, Let's Make Out
are you out of warranty?
Old Jan 2, 2008 | 08:28 PM
Just replace the O2 sensor. the system needs oxygen feedback to generate the correct mixture.
but are they SURE thats the cause ? or they just want to make some quick $$$ out of you ?
are you in warranty ?
Old Jan 2, 2008 | 08:38 PM
Redpit10's Avatar
G35 Convert
If it is the O2 sensor, than definately do the work yourself. It is literally one wire harness and a bolt. Simple as an oil change, maybe even more simple.
Old Jan 2, 2008 | 09:03 PM
DarkBrew's Avatar
Extraordinary Engineering
Can you confirm the DTC code?
I'm assuming this is the front O2 sensor...
Old Jan 2, 2008 | 10:37 PM
When you took it to a shop...are they Rotory certified?
If they aren't specialist on rotories take it to the correct shop or the dealer.
Ja, please confirm the cel code.
It's common to get a miss fire on our cars and then throw a cel code. Just reset the ECU for this and you will be fine. We need more info.
We just want to make sure the shop is not BSing for bucks.
vapor2
Nov 3, 2020 03:38 PM
SIllver
Aug 1, 2015 07:34 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
