ground wires
Old Dec 31, 2007 | 03:25 PM
Clown man's Avatar
ground wires
hey, I heard if I install the HKS twin power DLI II ignition amp that would rought idle. Is this true? or should I also get grounding wires. also do they really help or are the more a less a waste of money?
Old Dec 31, 2007 | 04:23 PM
WoodsOfGreenRx8's Avatar
Some people say grounding wires help clean up their idle & help with power transfer.. Keeping the lights on & not dimming when other things are turned on.. All depends on whether you have a $100 dollars to spend or not.
Old Dec 31, 2007 | 04:24 PM
staticlag's Avatar
The Professor
new sparkplugs
Old Jan 5, 2008 | 03:41 PM
nordichunter's Avatar
noob
if you want to do a grounding kit, dont waste your money on that pre-made stuff. go to an audio shop and get some power wire and some posts... may take a little more time, but it should end up being half of what big names will charge... plus you can then say that you actually made something that is on your car. As for the high voltage ignition amp....... must admit im clueless there
Old Jan 5, 2008 | 03:45 PM
altspace's Avatar
Eccentric Shafting
^+1 I did exactly that.
Old Jan 5, 2008 | 04:22 PM
mine
idles a lot better now
Old Jan 5, 2008 | 04:45 PM
romycha1's Avatar
You know, I read about how everyones idle is always improved.. I don't see any problem with my idle... Maybe I should do the grounding mod to my car to see what happens.
Maybe idle is rough, and I'm just use to it.
Old Jan 5, 2008 | 05:34 PM
1stgen8's Avatar
It does help a bit.....atleast that's what I've noticed in my ride.
Old Jan 6, 2008 | 11:59 AM
altspace's Avatar
Eccentric Shafting
Whatever you do, do not buy those eBay knock off kits with the gold plating. We installed one in a friends car and found that the round piece like xdeedubbx has on the battery was not conducive at all.
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
