Car feels slow, drive feels sloppy...
Old Dec 30, 2007 | 03:38 PM
dothackRAVE's Avatar
<3 Rotary
Okay, this might be an issue, or it may not, so I'm starting this thread here. This isn't an attempt to troll, I'm done with that.
Recently, I've started feeling that my 8 is slower than it was. The "feel" of the drive isn't as buttkicking as before. It's losing the "ooomph" when I start from a stop.
Maybe it's just me becoming more precise with my pedal work. This is my first car afterall. I did cause my clutch to start burning before, when I slipped my clutch at 5000rpm accidentally (I tested it a few days after that, trying to get the car moving from a stop in 6th gear. Didn't feel any slipping). Since then, I've felt a slight difference in drive feel. It might be just me being paranoid...
Have anyone else here experienced something similar? I don't have access to another RX-8 to test drive.
Old Dec 30, 2007 | 03:43 PM
dillsrotary's Avatar
jersey fresh
if anything it might be time to change your coils and your sparkplugs, how many miles do you have on the car?
Old Dec 30, 2007 | 04:17 PM
kersh4w's Avatar
Hit & Run Magnet
coils, compression test
Old Dec 30, 2007 | 06:25 PM
ActionAttackGoose's Avatar
Why the **** would you do this?
Old Dec 30, 2007 | 06:57 PM
zerobio's Avatar
Atomic 8
Redline it a bunch of times ... might clean out the carbon.
Old Dec 30, 2007 | 07:04 PM
<3 Rotary
It was apparently a test to see if its time for a new clutch.
So this is all from carbon? I do redline the car rather often..., about once or twice a week.
It's at 25,000 miles now.
Old Dec 30, 2007 | 07:10 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Troll pentance(sp?)......gotta love it!
Seriously...at 25k, I think I would go after the plugs(and maybe wires while you at it). Then comes the coils and possible compression test.........but I think you're probably okay on the compression based on what you have said.
Redline.................well, I do it at least twice each day.
Old Dec 30, 2007 | 07:13 PM
<3 Rotary
Spark plugs hm? I'm a mechanical n00b, so I'm curious about what you mean by "coils". The springs on the suspension?
Old Dec 30, 2007 | 07:15 PM
Mazurfer's Avatar
No................coils provide the electricity to the spark plugs. They can be found on the opposite end of the spark plug wires from where the spark plugs are.
Old Dec 30, 2007 | 07:19 PM
<3 Rotary
Gotcha.
How much do you think the entire charade will cost me? I'll prolly go for high end parts (within civilian accessible limits), so no Duralast nonsense.
Old Dec 30, 2007 | 08:02 PM
Gotcha.
in this order check these things...
plug wires tight. ? this is free.
look at plugs. if you have over 20k miles on them replace them.. 50 to 75 bucks
if those checks dont help replace the coils.. i have 0ne set left.. pm me if you want them.. new oem 129 bucks. useds much less.
Old Dec 30, 2007 | 08:27 PM
jowettw's Avatar
funemployed
When you say "sloppy", do you mean body roll and sway?
I've got that same feeling, but was thinking it was the tires ... ?
Old Dec 30, 2007 | 08:40 PM
<3 Rotary
No. The body roll is fine. It's just when I go from a stop.
Old Dec 30, 2007 | 08:42 PM
what is tire pressure for 1000 alex?
Old Dec 30, 2007 | 09:20 PM
RX8 dood's Avatar
If I'm correct....with my experience with other cars...and being I only had an rx-8 for 3 days I may be wrong...but you would test your clutch by pulling out in high gear...but the car should stall if the clutch is good.
Old Dec 30, 2007 | 10:35 PM
jowettw's Avatar
funemployed
Heh. I've tried that too. I try and keep it at 35PSI, but have tried 40PSI as well.
I guess that's what I get for cheaping out and getting SPTs!?
Old Dec 30, 2007 | 11:06 PM
i run the spts at 34 and they are fine. not sure what your issue is..
Old Jan 2, 2008 | 02:31 PM
<3 Rotary
Okay, I sent the car in for a full fluid swap today at the stealership. They were gonna charge me $500 for everything.
They also told me the spark plugs are worn out, and was gonna charge me $215 and more for them to be replaced.
I decided to do it myself. So, what do I need?
Old Jan 2, 2008 | 04:05 PM
Juice's Avatar
I made some poos
You are going to need 4 spark plugs:
2 trailing and 2 leading
http://www.sparkplugs.com/results_ap...1&AAIA=1431319
NGK is what you need, 2 of each of the plugs listed
For Fluids:
5 quarts of Oil, your choice. I've used 5w20 Castrol GTX and recently switched to 5w30 Royal Purple Full Synthetic (Works Great, Very Smooth)
Oil Filter, I use Bosch 3300
For Transmission I use Royal Purple SynchroMAX (You'll need 2 quarts, it only takes 1.8 though)
For Differential I use Royal Purple MAX Gear 75w90 (Also Need 2 Quarts, but it only takes 1.5)
I haven't replaced Coolant yet so I can't help you there.
I think thats it for Fluids, besides Brake Fluid.
There are DIYs for all of this in the DIY forum so check them out
EDIT: All of the fluids I listed are what I use, and can be replaced with whatever you prefer. Others seem to like Redline for trans and diff. Some use Full Snthetic for engine oil others use dino. It all up to the owner of the car so whoever responds lets not get into a debate over what everyone should use. There are already places for that.
Old Jan 2, 2008 | 04:25 PM
Are you sure it's not your mind?
you asked.... It would be a waste to begin replacing parts just because you think it is slower.
You may have gotten use to the car and it's acceleration.
Old Jan 2, 2008 | 04:54 PM
RojoOcho's Avatar
Greensboro's Finest
My SPT's have done a great job for me too...
Old Jan 3, 2008 | 09:23 AM
1QWIK7's Avatar
Bingo.
I dont mean to sound offensive since this is an 8 forum but the 8's acceleration isnt mind boggling to begin with. Im sure after months of daily driving it, it will feel like any other car out there.
Check simple DIY things first. If they check out fine. Just relax dude and enjoy the car and stop worrying.
Dokuji
Nov 1, 2016 02:51 PM
dbarber
Jul 25, 2015 01:34 PM
yapakanichi
Jul 20, 2015 02:17 PM
westgman
Good Guy/Bad Guy
Jul 15, 2015 11:18 PM
