What size/offset wheel for 275/40-17 track tires?
Old Dec 28, 2007 | 08:11 PM
altiain's Avatar
Sparky!
Title says it all. I'd like to run a set of 275/40-17 RA-1s or R888s on the car next year for track days. The car has RB springs and Konis. I'm assuming a 9" or 9.5" width, but what offset should I be looking for?
Thanks in advance.
Old Dec 28, 2007 | 08:42 PM
Juice's Avatar
I made some poos
9.5 +45
Old Dec 29, 2007 | 12:43 AM
TrochoidMagic's Avatar
is adjusting valve lash
try my set-up: RB springs, 17x9.5 +38 enkei rpf1's (from endless rotary auto rnd), falken azenis, and to complete the pkg; some nice sways.
thats what i'd like to run when i track sometime next year...just hope to have all the stuff mentioned above by then.
Old Dec 29, 2007 | 08:03 AM
altiain's Avatar
Sparky!
So have you actually mounted the RPF1s with that offset and 275s, or is that what you're hoping to use?
Old Dec 29, 2007 | 11:39 AM
c41250n's Avatar
17x9.5 +40
Old Dec 29, 2007 | 02:43 PM
Endless Rotaries's Avatar
I have a pretty good selection of Enkei Japan wheels that should fit with that setup.
Enkei NT03+M makes a 17x9.5 +44 offset, clears big brakes too.
That's what I was going to run for track.
Rishie
Old Dec 30, 2007 | 05:29 AM
not yet. i was debating 17x9. but was strongly recommended to go with 17x9.5 with +38. and as i looked and researched for tire selections... i found that this is the medium range in what i want to compromise for a shorter tire. the stock tires run 25.9 and the 275/40/17 is 25.6. so if running 17x9, 255/45 will get me a really short tire at 25 o.d.
and i was forewarned of slight, but only "slight" fender rolling to get those baby massaged in there... the rears only. which won't scare me off.
so waiting for rims to arrive. seems like rishie is the man to be getting ur enkei's from...
Old Dec 30, 2007 | 05:37 AM
Originally Posted by c41250n
17x9.5 +40
and it looks very aggressive on ur car sir. i may not need worry as the RB drop is hardly a "drop".
but DAMN, those offset and SSR's look HOT! i've always had/love ssr's, but too bad its too damn rich for my blood brand new.
Old Dec 30, 2007 | 01:43 PM
c41250n's Avatar
naw....the one on my car now are 18X10 +24 front and 18X10 +21 rear
this is 18X9.5 +40 all around on the track!
and thanks for liking my wheels!
Old Dec 30, 2007 | 02:39 PM
Hi Trochoid,
i'll check with Enkei on WEds to get your tracking #.
woot woot, can't wait to see that fitment.
It's gotta be incredible. I dropped to 17's and i saw a 15% increase in fuel economy with 245 wide tires. Not too mention the car accelerated much faster.
Rishie
Old Dec 31, 2007 | 12:21 PM
BigOLundh's Avatar
#1 Legend
THATS A MEAN PIC!!!!
Old Jan 2, 2008 | 05:30 PM
Originally Posted by Endless Rotaries
Hi Trochoid,
Rishie
if ur seeing 15%, then i should see less than that on assumption. it is only .3inch off from the factory tire o.d.
but i guess that size would be the most useful if running in autox. i can't really complain here as i am getting the added width and still a lil bit shorter tire... it should still be lighter than the oem wheel/tire setup no?
Old Jan 2, 2008 | 05:59 PM
I hear you can get better times with the 18" x9.5 than a 17x8.5
Old Jan 2, 2008 | 06:10 PM
what about 17x9.5 instead of 8.5...
Old Jan 2, 2008 | 06:28 PM
turborx8's Avatar
Boost 4 Life
so whats the advantage of going 17x9.5 over 18x9.5 ??
I was going to order these in a few months.
http://www.good-win-racing.com/Mazda...21-1051FD.html
Old Jan 2, 2008 | 07:28 PM
mac11's Avatar
Rotary , eh?
the cost of 17" wheels and tires is less.
the rotational wiehgt is closer to the hubs.
Old Jan 3, 2008 | 03:27 AM
^^+1. well, there are benefit in many ways if you look at it.
some of it are very basic if you really think about it. lets set the example to be the same in terms of tire... in 18s, picture the road as the mechanical leverage on ur tires and the same for 17s. the larger diameter will have a greater mechanical force on the rotors and therefore will make it harder on the pads to lock the rotors... but too small of a rim can easily "lock" the rotors up.
so having smaller rim and tire pkg will just maximize ur tire potential given less diameter to have to stop.
and of course the obvious: less diameter and rolling mass. a decrease in % or a "shorter" tire will accelerate faster along with engine speed.
to make it easier, the concept with a bicycle are practically the same. its all in gearing selection...
and yeah, like what mac11 said too... tire selection are wider and its also cheaper.
there really isn't a definite rule that mazda chooses 18s over 17s cuz its better. they're just following the trend in modern cars look "classier" with bigger wheels and less tire.
Old Jan 3, 2008 | 03:30 AM
hard to explain fully in detail as there are many ways to find whats right for ur usage.
it'll be better if you have a specific question or concern that will land you what will go right with ur car.
Old Jan 3, 2008 | 04:00 AM
Ditto on troichoids words and troic your wheels should have left enkei today.
I should have tracking by tomorrow. You'll have em next week regardless.
rishie
Old Jan 3, 2008 | 04:19 AM
^^woo-hoo!
thanks rish. and i'll give you a call sometime in the future for the center caps when i have enough to pick up that luxury piece.
any chance that those pieces will go up in price?
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
bullbuchanan
26
Mar 24, 2016 12:37 PM
stickmantijuana
10
Oct 27, 2015 04:11 PM
EfrainOlivares
Aug 14, 2015 06:17 PM
Brandonien
Jul 30, 2015 12:33 PM
