confused
Old Dec 24, 2007 | 11:18 PM
beyondelay's Avatar
Question confused
Hey everyone i recently became a proud owner of a 04 rx8 with 45k miles on it. i was wondering what kind of prevenative maintance youns guys do to keep your cars running in tip top performance. The information would be greatly apreciated.
Thanx
Old Dec 24, 2007 | 11:38 PM
DarkBrew's Avatar
Extraordinary Engineering
Congrats on the purchase and welcome to the forum!
Please add location to your profile.
Since you bought it with some miles you should check a few things.
Get compression measured.
Make sure that the recalls have been addressed.
You may run into the coil failure issue soon so plugs, coils and wires should be inspected soon. Don't worry. They're relatively cheap if you buy from the forum vendors and install them yourself. check the DIY section.
Make sure you change the oil on schedule and check the level every couple of fill-ups.
Last, make sure you rev the engine regularly with excursions to redline at least once per drive (once the engine is warm).
Once you're hooked on the car none of this will seem like an issue.
Read the stickies at the top of each forum.
Use the search feature before you post a newbie question so you don't get flamed.
Let the mods begin!
Old Dec 24, 2007 | 11:46 PM
dont forget to read that silly owners manual in the glove box..
Old Dec 25, 2007 | 12:33 AM
Listen to Swoope and Dark
Even tho you might be an expert in everything and never look at manuals, still, look at it for once. I know yeah its boring yada yada yada all the time but u might be able to find some useful info in there ...
Old Dec 25, 2007 | 09:06 AM
max5roadster's Avatar
INDY RX8 CLUB - Officer
I would suggest you use a 5-30 oil rather than the 5-20, plus if you want, might not be a bad idea to pre-mix. happy motoring and welcome!
Old Dec 25, 2007 | 12:08 PM
staticlag's Avatar
The Professor
best thing you can do: make careful shifts
then make sure all the oils are changed regularly: tranny, diff, engine...
Old Dec 27, 2007 | 12:56 AM
beyondelay's Avatar
Thanx fella's for the info. I'm glad to hear that i should redline the car! I had a celica gts and that thing couldn't take the 9000 rmps it blew up twice. I read all the bad threads about this car but it didn't scare me off. The car turns and burns the mustangs, let alone the feeling you get railing a curve on a pennsylvanian country road. I have kept the owners manual by the john for 3 weeks now lol so i pretty much know that thing.
airlive
Jun 28, 2020 07:46 AM
Azki23
Jun 27, 2018 03:48 PM
poacherinthezoo
Aug 3, 2016 11:01 PM
wanted797
Aug 26, 2015 11:24 PM
