code scanner...will this one work on rx8
Old Dec 24, 2007 | 03:35 PM
chancejat's Avatar
Drive it like u stole it!
http://www.actron.com/product_detail.php?pid=16298
it says its CAN compliant....then it should work, right???
im just trying to make sure the only code i get is my 2nd o2 sensor bc of my cat delete
Old Dec 24, 2007 | 03:37 PM
DOMINION's Avatar
I don't buy Kool-Aid
From what I was told no. You need the kind like at the dealer. They run about $800.00-$1,500.00
Old Dec 24, 2007 | 03:41 PM
The iDS at the dealer is about 8K from Mazda
You can get a RX-8 compliant Scanner from Hymee...or from Harrison or others.
Do a search .....
Old Dec 24, 2007 | 03:44 PM
DarkBrew's Avatar
Extraordinary Engineering
Why not scan gauge II ?
http://scangauge.com/
Reads codes fine on my RX8.
The one linked by the OP looks like it should read the codes as well...
Old Dec 24, 2007 | 03:46 PM
StealthTL's Avatar
Metatron
As long as it reads the Can-bus protocol, it will work.
$80, Ebay.
S
expo1's Avatar
He's as bad as Can
Yes it should work, just make sure you can return it if there is a problem. But as others said you do not need dealer only tools to read and reset CEL codes. I have two myself, the Scan Gauge II and the Harrison one.
Old Dec 24, 2007 | 03:52 PM
chancejat's Avatar
sweet i hope it works there 40$ on amazon........and as long as it can tell me the code number thats all i care about
Old Dec 27, 2007 | 04:01 PM
DOMINION's Avatar
Thumbs up
$80, Ebay.
S
Thank you sir!
gregs
Aug 6, 2015 11:43 PM
SIllver
Aug 1, 2015 07:34 PM
MarkX
Jul 31, 2015 07:50 AM
Ajmurphy85
Jul 30, 2015 07:51 AM
netrovers
Jul 20, 2015 03:32 AM
