Over revved the motor
Old Dec 24, 2007 | 12:38 PM
xr4tii's Avatar
silverx8 04MT
Anonomyous:
I was going about 72 when I downshifted to second. Before, I knew it the rev buzzer went off and I pushed the clutch pedal back down and found the right gear (4th). No problems yet, but must have gone over 10K.
Old Dec 24, 2007 | 12:40 PM
doesnt matter, it wont die
you should worry the tranny first b4 the motor
Old Dec 24, 2007 | 12:43 PM
xr4tii's Avatar
silverx8 04MT
I changed the fluid to synthetic right after I got the car new. My Xr4ti taught me that the fluid is the most important part in the transmission after being rebuilt twice in the first 80K.
Old Dec 24, 2007 | 12:52 PM
I have yet to rebuild mine
Old Dec 24, 2007 | 12:56 PM
If you rev too high you will hit the rev limiter and the fuel will cut off and you will go in limp mode and only beable to drive around 20mph.
That didn't happen so don't worry about it.
Old Dec 24, 2007 | 01:22 PM
Another HUH?
Old Dec 24, 2007 | 01:44 PM
It is a whole different matter than a combustion derived over-rev.....
The pressures are a whole lot higher when that happens........
Old Dec 24, 2007 | 02:18 PM
Startl_Respons's Avatar
He is talking about having to rebuild the engine in his Merkur XR4Ti. I think he's on his first RX8 engine.
How did you like the Merkur?
Old Dec 24, 2007 | 02:24 PM
xr4tii's Avatar
silverx8 04MT
The Merkur was great, but a little soft. It was the tranny that gave out, in particular the shaft bearing. After reading the factory bulletin that specified the $16 a quart fluid, all problems stopped.
The 626 that I had at the time felt a little more stable at speed.
The thing is that since the motor was being over revved by the momentum, the fuel cut out did not slow me down. But it did not go into limp mode, so I am OK?
Old Dec 24, 2007 | 02:27 PM
If it didn't break at the time...you should be golden
The engine is balanced OK free spinning to 13K at least....when you add compression pressures...you would have been F**Ked
Old Dec 24, 2007 | 03:21 PM
why give him answers ? Why ?
Old Dec 24, 2007 | 03:24 PM
Huh?
Old Dec 24, 2007 | 03:42 PM
Blah
Old Dec 24, 2007 | 04:02 PM
Merry Christmas
Old Dec 24, 2007 | 04:24 PM
Renesis07's Avatar
Vtak just kicked in yo!!
Ive done this to mine a couple times, the last time I did it I pussed out half way on letting off the clutch and hesitated with it half way down then let off which was stupid of me; I toasted my clutch, my car smelled like a burnt clutch that whole night and now it feels like it has alot less pressure so I probably need a new clutch.......dammit
Old Dec 24, 2007 | 07:19 PM
Gopherage's Avatar
Gophericer...?
Hey if he survived a Merkur's problems then he can survive anything that will go wrong with an 8 although it's 8's it's the engine to worry and with Merkurs it was anything and everything attached to the main block. My friend is on his 5th Merkur he says once you catch the Merkur bug you can't get away from them.
Old Dec 27, 2007 | 12:41 AM
xr4tii's Avatar
silverx8 04MT
Yeah, I feel kind of funny just checking the oil when I am under the hood of the RX8. The Merkur and I were a lot more intimate. Air conditioning hoses, radiator, batteries (right over the turbo), dipstick (it really didn't take 6 quarts!), water pump, belts, hoses, etc...
Funny thing is that they both get 19 MPG, go figure.
Old Dec 27, 2007 | 09:17 AM
TheKDog's Avatar
2007 BB RX8 GT
It's a rotary.
It can rev to 50k, at least.
Old Dec 27, 2007 | 09:50 PM
Torchmonkey's Avatar
The 1.3 rotary can get up 12.5 k without damage. I think at 13k, it will be destroyed by "harmonic distortion"...or a gremlin.
mdl0209
May 23, 2019 05:46 PM
bosstin87
Oct 5, 2015 06:52 AM
Luke.s
Sep 30, 2015 05:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
