warranty question
Old Dec 20, 2007 | 03:36 PM
eclipsegsx's Avatar
F-14 on afterburners
warranty question
hey guys, quick warranty question for a somewhat new owner
if i have the extended warranty, Do I have to fill that maintenance log up that comes with it, each time the car is serviced? I bought the car used with 9.5k on it and I have all the dealer papers on whats done, etc but the log is not filled.
will not filling this maintenance log void it? Also is there any other paper the dealer usually writes on to keep a record of the maintenance? I can't seem to find it with the papers I got. I have 12.6 k on it now.
Old Dec 20, 2007 | 03:40 PM
SideOfBacon's Avatar
im still searching but no luck.. there is a site through mazda where you can add all the services you have had done to your 8 so they are accessible ANYWHERE where internet is available. Will update when I find it. was posted here but search came up short..
Old Dec 20, 2007 | 03:41 PM
http://www.mazdausa.com/MusaWeb/disp...ersHome.action
try here..
Old Dec 20, 2007 | 03:47 PM
eclipsegsx's Avatar
thanks caveney81, ill register. Also wanted to know if I had the recepits and the maintenance log is not written up by the dealer, would that still be considered in case I need to get something under warranty.
Old Dec 20, 2007 | 03:51 PM
you mean since you bought it theres nothing as far as logs go previous to you purchasing? your wording and question is a bit choppy... try rewording perhaps?
Old Dec 20, 2007 | 03:58 PM
eclipsegsx's Avatar
Sorry caveney81,
What I mean is, for the warranty and extended warranty to work, does there have to be a written log of all scheduled maintenance performed on the car, or can recepits work? because I believe the warranties will be void if the car does not have its scheduled maintenance done? Correct me if i am wrong here.
Old Dec 20, 2007 | 04:02 PM
Sorry caveney81,
you are correct... the scheduled maintenances do have to be done in order for warranties to hold up. with 30k being the first one.
http://www.mazdausa.com/MusaWeb/pdf/.../04_RX8_MS.pdf
Old Dec 20, 2007 | 04:03 PM
huzer21's Avatar
I've never heard of having to prove regularly scheduled maintenance was performed in order to keep a warranty intact. (Note that I said prove, I'm not recommending it not be done.) I've had no issues with any warranty claims on my car, nor have I on past vehicles.
Old Dec 20, 2007 | 04:06 PM
ZoomZoomH's Avatar
Mulligan User
me neither.
but i also have never bought an extended warranty, so i don't know how that works...
Old Dec 20, 2007 | 04:07 PM
the 30k and 60k maintenance (per dealership, maybe they BSed me) were required and proof of to keep extended warranty valid.. perhaps a scam just to get more money from me? could always ring mazda for verification OP.
Old Dec 20, 2007 | 04:08 PM
eclipsegsx's Avatar
Wooo
Well I guess I will go in for my 15,000 mile maintenance (replace oil and oil filter and clean the air filter) by the dealer. Recepits will work I guess in case I have to "prove" maintenance.
Old Dec 20, 2007 | 04:09 PM
huzer21's Avatar
I had an extended warranty on my Yukon and never had to prove any maintenance. And that lemon had almost $10k in warranty work done to it. I guess it all depends on the fine print on the extended warranty. As far as factory, they aren't going to make you drag in receipts or a maintenance log to prove anything. If you've neglected maintenance enough to where it caused failure, that will be obvious enough.
Old Dec 20, 2007 | 04:21 PM
eclipsegsx's Avatar
yea on the extended warranty (btw covered till 2012/75k miles) it says "Contract owners responsibilities: owner must satisfy all regular maintenance. failure to follow the manufacturers recommendations may result in a denial of coverage"
I guess it doesnt necessarily mean "keeping a log" but making sure the maintenance is done in accordance to the manufac. requirements.
LB2739
Jul 9, 2019 02:25 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
#1Hoochie
Oct 16, 2015 10:35 PM
TJSiegrist
Sep 10, 2015 09:29 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
