RB rear swaybar bushing???
Old Dec 18, 2007 | 08:59 PM
CURED RX8's Avatar
I like the color
Racing Beat offers two different Bushings for the rear swaybars, one for the 04-05RX-8 and one for 06-07 RX-8. What changed starting in 06' with the rear swaybars? Or is the swaybar the same and the mounting different?
Old Dec 18, 2007 | 09:07 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
If I remember correctly............in late 2005 Mazda changed the bushings to a shorter bushing, that was it...............mounting is the same.
When I bought mine from RB, the rear came with four bushings and you only use the two that are the size you currently have.
Old Dec 19, 2007 | 09:06 AM
CURED RX8's Avatar
I like the color
Thanks Mazurfer for the info.
Folks with different extra bushings could probably swap them with each other.
Part # 95828 (04-05 RB rear bushing set) $4 + shipping thru RB
Part # 95997 (06-07 RB rear bushing set) $4 + shipping thru RB
Not a huge savings since you'd probably be ordering front ones also anyway when you replace, but a couple bucks is good.
I'm still torn between RB sways or Progress Tech!
Old Jan 4, 2008 | 03:18 AM
Senna's Avatar
Merchant Of Pace
I have RB sways and endlinks coming tomorrow. I'm considering just going with a set of energy suspension bushings/clamps with the zerk fittings for the front. I believe they need to be 32mm.
Is anyone aware of a good replacement bushing with zerk fittings for the rear.
Digitz0070
Oct 7, 2015 12:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
