Bose center dash speaker
Old Dec 15, 2007 | 11:35 PM
alphamale's Avatar
alphamale
Are most people here disconnecting their center dash speaker if they upgrade their systme with a different amp?
Old Dec 16, 2007 | 01:47 AM
romycha1's Avatar
Why would you disconnect it? I'm actually going to be adding in another amp tomorrow and I'll be leaving mine connected.
Old Dec 16, 2007 | 02:29 AM
G3tR3DDY2GR3DDY's Avatar
nope pretty sure noone has ever done that for any apparant reason...
Old Dec 16, 2007 | 03:52 AM
Luftwaffle's Avatar
I pulled mine and replaced it with a small 3" Kicker.
Old Dec 16, 2007 | 01:07 PM
alphamale's Avatar
alphamale
The reason was because when I buy an amp, it restricts my choices having to have a 5 channel amp, or a 3 channel and 2 channel etc. So, I thought that the most straight forward thing is to use a 4 channel amp powering the two door speakers and the two rear deck units. Unless the speaker up front has its own amp, then I wouldn't really have to worry.
Old Dec 16, 2007 | 08:23 PM
romycha1's Avatar
Oooohhhhhhhhh... You mean to totally replace the factory amp.
I thought you meant to ADD another amp... I'm more than sure all the speakers are controlled with the one amp, and that speaker doesn't have it's own amp.
Well... if you are going to replace all the speakers with higher-end ones and have them amplified.. then yes, I would just disconnect the dash one... That is what I would do.
Old Dec 16, 2007 | 08:38 PM
alphamale's Avatar
alphamale
But the speakers in the door do have their own amps, right?
Old Dec 16, 2007 | 09:00 PM
this is true...
the door speakers do not have their own amp. the rear amp in the deck controls all the speakers. The speakers in the door are just mid-bass door speakers nothing special.
Old Dec 16, 2007 | 11:19 PM
alphamale's Avatar
alphamale
this is true...
Huh. I could have sworn I read a post on here about little amps accompanying the speakers in the door for the Bose system. No amps in the doors makes more sense to me, though. Thanks for the clarification.
Old Dec 17, 2007 | 01:18 AM
Luftwaffle's Avatar
The door speakers do have their own little amps. I pulled them out when I ran wire from my multi-channel in the trunk to the doors. At least they do in the Bose setup.
Old Dec 17, 2007 | 06:13 AM
kimota's Avatar
I disconnected the Bose center channel speaker after my stereo upgrade as it threw off my sound.
Note I added 2 amps (one 4 channel, one 1 channel), two subwoofers and replaced all my cabin speakers.
If you do plan on keeping the center channel I'd suggest you replace the Bose center channel and power its replacement with your aftermarket amp.
Old Dec 17, 2007 | 09:31 AM
romycha1's Avatar
Wow... learned something new. Where are those amps? Are they in the door? I've never taken a look behind the door panel so I don't know..
So then... the amp in the back controls the rear deck speakers, and the center dash one?
Old Dec 17, 2007 | 11:54 AM
alphamale's Avatar
alphamale
Confusing, isn't it?
Old Dec 17, 2007 | 12:40 PM
Luftwaffle's Avatar
https://www.rx8club.com/series-i-interior-audio-electronics-24/pictures-bose-door-woofer-amp-21551/
Astral's Sticky at the top of this forum is very useful, reading through it and all the links will answer a lot of questions.
Old Dec 17, 2007 | 12:45 PM
kimota's Avatar
Luftwaffle is WISE that sticky was super SUPER did I say super usefull when I did my install it even has pics and locations of all the Bose amps.
Old Dec 17, 2007 | 05:00 PM
alphamale's Avatar
alphamale
https://www.rx8club.com/showthread.php?t=21551
Thanks! I actually saw those pics before, but didn't look closely enough to notice the little amp in the door next to the speaker. I guess I thought it was a crossover.
Old Feb 8, 2008 | 07:54 PM
Socket7's Avatar
ಠ_ಠ
Thread! I command you to come back to life!
This is all well and good info, but how do you actually gain access to the center speaker to replace or rewire it? Will it be obvious if I pull out the radio?
Jst4fun
Mar 5, 2021 07:16 PM
FubarI33t
Sep 28, 2015 08:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
