tire size and rim offset ?
Old Dec 14, 2007 | 06:43 AM
frankcastle123's Avatar
frank castle
Question tire size and rim offset ?
i recently purchased my 3 set of wheels for the car which are 19x8.5 and 19x9.5 rear with 35mm offset. question is will the back weels rub with a 275/30-19 with s-tech lowering springs....
Old Dec 14, 2007 | 01:59 PM
Endless Rotaries's Avatar
Yes it will certainly rub. You need to roll about 10mm out of your fender sir.
A 9.5" +45 will fit without rubs from my experience in that tire size. You're off of that by 10mm.
Rishie
Old Jan 8, 2008 | 08:19 PM
magikone69's Avatar
im looking to get a similar set up 19x8.5 front with 35+ and 245/35/19..........rear is at 19x9.5 35+ with 265/30/19....
im on jic's and can adjust the height if necessary, but im hoping it can be avoided...i really dont want to have to roll anything.
will the slimmer 265 tire prevent rubbing???
Old Jan 9, 2008 | 01:37 AM
If you don't want to roll i think you're SOL.
The 265/30/19 is just too short a tire imho. You need either a
245/35 = 275/30 almost, even 275/30 is a little shorter than stock.
or go with 255/35/19 in the rear. But i still think you'll need a minor roll.
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
CMRine04
Sep 17, 2015 10:04 AM
fireishot34
Sep 5, 2015 06:45 PM
