TAILLIGHT FOGGING... need help!
Old Dec 13, 2007 | 04:26 PM
blackcreamer's Avatar
My drivers side tailight suddenly started fogging up. As always warrenty just expired only 3 months ago. i only have 59000km on the car and i think that this is total bullshit.
Anyone have any ideas on anything i can do. $200 bucks for a new tailight is my last option.
Old Dec 13, 2007 | 04:27 PM
chetrickerman's Avatar
mine too, but im pretty sure there are multiple threads on this. hold on, i will get a link
Old Dec 13, 2007 | 04:28 PM
j67345's Avatar
It'll be covered under warranty....there is a TSB for it. I had mine replaced last year
Old Dec 13, 2007 | 04:30 PM
j67345's Avatar
hit this up for the TSB
http://www.finishlineperformance.com/rx8/bulletins.html
Old Dec 13, 2007 | 04:44 PM
ok, i dont know how to help you. its normally a warranty thing, but since you dont have one, you might have to buy a new one
Old Dec 13, 2007 | 04:45 PM
his warranty is expired
Old Dec 13, 2007 | 04:53 PM
Myardor's Avatar
want to save $200?
Then you have to work to earn it.
1. remove taillight
2. open the taillight, ie remove the "seal"
3. Dry the taillight, ie might have to use a hairdryer or ..heres where
you have to use common sense and use it to dry the lite, just dont bake it in the over.
4. Look at the seal, is it broken? if so you will need a new one
where? make ur own. again common sense. worst case, go to the local parts store /wallyworld and get some kind of sealer/tube type
5. put that seal/sealer and put it back, might have to wait till the sealer sets ( if u used the tube type)
6 re install the tail light.
Note that this will take some time, its not a 5 minute job.
good luck
Old Dec 13, 2007 | 05:17 PM
thanks guys, i did some searching after my post and found the SB. I will dry it out and replace the seal. Dealer says its only $20 bucks for the seal. If that dont work, ill do the ebay thing, a used light is pretty cheap.
Old Dec 13, 2007 | 05:23 PM
Gecko69's Avatar
why is your warranty expired at 57000km???/ I have almost 70000km on mine and they are still replacing my headlight bulbs under warranty for me......you warranty should not be gone yet ..... are you past 36mnth/60000km???
Old Dec 13, 2007 | 05:37 PM
RotaryP7's Avatar
Seriously.. FML..
Hit the tail light with a hammer and clean inside it. It works!
Old Dec 13, 2007 | 05:41 PM
Renesis07's Avatar
Vtak just kicked in yo!!
drill hole in bottom
Old Dec 14, 2007 | 09:25 PM
rotormech's Avatar
open it up, dry it out and place one of those silica bags you find in brand new computer packaging boxes in it. That might solve the problem....come to think of it, I'm gonna try that=)
Old Dec 14, 2007 | 09:36 PM
ken-x8's Avatar
I presume you're serious. But either way, that worked like a charm when a tailight on my daughter's Accord kept filling with water.
Ken
Old Dec 15, 2007 | 02:33 AM
NgoRX8's Avatar
fogging up and filling with water are two separate things. you can't stop fogging by drilling a hole.
New Yorker
40
Mar 22, 2022 06:01 AM
cretinx
168
Mar 12, 2009 05:36 PM
ddark
44
Jan 3, 2006 11:47 AM
Reactionary
General Automotive
Feb 2, 2005 08:43 AM
Gaels22
Canada Forum
Sep 4, 2003 06:18 PM
