widebody + handling question
Old Dec 12, 2007 | 06:43 PM
stickmantijuana's Avatar
Unregistered User
say if one were to put spacers to lower offset in the rear and leave the front offset stock. would this cause any unfavourable handling dynamics? mostly asking about rear effectively having less roll than the front if just the rears get wider.
Old Dec 12, 2007 | 06:47 PM
chetrickerman's Avatar
well staggering affects handling. i would assume since your lowering the offset, you are going wider. you wouldnt handle as good then
Old Dec 12, 2007 | 06:52 PM
Unregistered User
but your rear roll resistance should go up, so is effective 'center of gravity' not really but you can see with wider stance, it'd make the car harder to flip.
i understand why staggering would affect handling, still wondering whether just going lower offset in the rear would affect the handling as well.
Old Dec 12, 2007 | 07:02 PM
well this car is already hard enough to flip. but im not sure about the effect of offset on handing
Old Dec 12, 2007 | 07:15 PM
nuke0907's Avatar
Never Blend In
understeer. thats what mine does.
Old Dec 12, 2007 | 08:39 PM
also keep in mind you will more than likely need spacers with a hub centric ring...
Old Dec 12, 2007 | 09:03 PM
R Magic's Avatar
^^ what he said..
Old Dec 13, 2007 | 03:37 AM
Endless Rotaries's Avatar
This all depends on the current handling characteristics of your car and your driving style. This is a relative question to tell you the truth.
When you reduce the offset you are also changing the "lever" point for your suspension, effectively changing the optimal desired spring rate.
Rishie
Old Dec 13, 2007 | 04:16 AM
you really need to drive the car, and go from there...
no way you are going to figure it out before you drive it for a long while..
you have so so so many variables going on.. patience....
imho. you might have the car that really really needs some or a fair amount of stagger..
but drive learn, then buy... wonder what the speedsource guys are running? that might be a start..
have you sent a pm to rgonza???? he is in the know here..
WranglerFan
Nov 5, 2017 09:35 AM
Brokegang
Jan 3, 2016 12:45 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
Wurromurro
Sep 20, 2015 05:02 PM
CMRine04
Sep 17, 2015 10:04 AM
