Question about offset
Old Dec 12, 2007 | 12:00 AM
eastaznboi's Avatar
Hey guys, I don't know much about rims and offset. I'm looking to buy a set of g-games off somebody i know, they're 19x8 with an offset of +48, he has 235/35/19 tires on them. How would that fit on our 8's? Or would I rub or have my wheels sticking out or something? any replies would be appreciated... thanks in advance! anybody know what the offset on the our stock rims is?
Old Dec 12, 2007 | 12:04 AM
ocrapitzleon's Avatar
fō'tə-jěn'
youre good +48 is real safe offset, and 235s are real thin
also you should be good even with a aggressive drop
ergo. get them
Old Dec 12, 2007 | 12:50 AM
Endless Rotaries's Avatar
It's gonna look SUNK and the tire is one size too small.
Ideally go with a 245/35/19
I'd strongly suggest something like 19x8.5 +35 offset for proper appearance.
Rishie
Old Dec 12, 2007 | 03:43 PM
eastaznboi's Avatar
thanks guys for the reply, would anybody happen to have an offset of +48 on their car. I'm tight on time and have to decide quick!
Old Dec 12, 2007 | 04:14 PM
It's gonna look super sunk.
Pretend you lower your car on the stock wheels. That's how sunk it will be.
Old Dec 12, 2007 | 08:27 PM
aliveoutofhabit's Avatar
What Rishie said. I believe the stock wheels are 18x8 +50? These wheels will only sit 2mm further out... I don't think it's doing to look very good at all. They will definitely fit, but they won't look too good.
Old Dec 12, 2007 | 08:30 PM
eastaznboi's Avatar
endless, what do you mean by sunk?? my car is already lowered on s-techs with the stock wheels right now, it doesn't look bad imo. by sunk, do you mean it doesn't line up with the fender, and is further inside? show a pic if you can
Old Dec 12, 2007 | 09:16 PM
thecow135's Avatar
yes.
Old Dec 13, 2007 | 03:32 AM
It will technically sit in virtually the same position as your existing stock setup. The only difference is:
1. You now have a shorter tire
2. When increasing the diameter of the wheel it will create an optical of illusion of sorts and give the appearance of being more "sunk further into the wheel well" than the stock 18" setup.
3. Beauty is in the eye of the beholder.
I wouldn't do it on my car, even if it was a great deal. There are dozens of great deals out there for better fitting aftermarket wheels.
Rishie
nferguson88
Oct 6, 2015 12:45 PM
jer2911
Sep 29, 2015 06:37 PM
kody59
Sep 28, 2015 03:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
