question about my rim selection
Old Dec 11, 2007 | 01:08 PM
94MR2-T's Avatar
I have a ? about the rim sizes I have chosen. I am lowered on tein springs.
rims are
rota p45r 18x9.5 +20 offset front and rear
tires, I will be stretching 245/45/18's on them
is anyone running this setup or anything close to this? I am wondering if I will have to roll or pull the fenders and i am concerned about rubbing.
Thanks for your help
Old Dec 11, 2007 | 02:01 PM
staticlag's Avatar
The Professor
You will rediculously rub, you need to run an offset +40 or so with the 9.5 inch wide rims.
Old Dec 11, 2007 | 08:06 PM
RA-Eight's Avatar
Scuderia
Major rubbage
Old Dec 11, 2007 | 09:20 PM
bruce_van's Avatar
Bruce Van
Besides rubbing, won't those wheels stick out way beyond the fender?
+20 is awefully low. I'm at +35 on 8.5" wide rims and I can see it sticks just a tad beyond the fender wall.
Old Dec 11, 2007 | 10:45 PM
ocrapitzleon's Avatar
fō'tə-jěn'
my high 30s is already rubbing my ******* dry
yes i shaved my fenders, but 275 tire size
going to run 265 soon
Old Dec 12, 2007 | 12:24 AM
Endless Rotaries's Avatar
Ya umms it won't happen without a good 4 degrees of camber.
1. 245/45 is taller than stock so you'll rub more there.
2. Need mad camber
3. Must run a 225/45/18, STOCK SIZE TIRE. Looks great.
I believe if you run the right camber, dump the **** out of it, and stretch 225/45's on those 9.5's. You might be able to make this work.
I did 17x9.5 +25 test FIT ONLY with some 245/45/17 tires. FYI. Didn't drive on it. Looked to clear.
i have mounted 225/45/18 on 18x9.5 Enkei RPF1 and it looks SICKKKK if you're into it.
THIs IS OUr STOCK BRIDGESTONE STRETCHED ON 9.5".
Rishie
Old Dec 12, 2007 | 12:08 PM
94MR2-T's Avatar
That looks sick^^
The thing is I have to use these tires somehow 245/45/18, I cannot afford to buy new tires again, these have only 500 miles on them. I was under the impression that +20 offset would stick the rim 2" further out away from the car which would make it clear everything in the wheel well....... So to make this work I would need Atleast a +25? Wen you add a spacer that subtracts from the offset number correct??
Old Dec 12, 2007 | 12:17 PM
94MR2-T's Avatar
On the wheel and tire calculator, it says they will stick out 30 mm (1.2'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Im pretty sure 1.2" will fit under the stock fenders? Maybe not
Stock rx8 has a +50 offset with 8" wide rim correct?
Old Dec 12, 2007 | 12:18 PM
aliveoutofhabit's Avatar
Your understanding of offsets is correct. However running a lower offset will cause rubbing withing regards to the fenders. If you rolled and pulled your fenders you could probably make this work.
I would recommend trying to sell those tires on a 350Z/G35 forum... they're just too tall for our cars.
If you were going to run them on a 9.5" wheel you would probably want an offset in the low-to-mid-40s.
Old Dec 12, 2007 | 12:26 PM
94MR2-T's Avatar
For every +5 offset the rim will sit .2" closer to the car......
Old Dec 12, 2007 | 12:27 PM
94MR2-T's Avatar
aliveoutofhabit. Thanks for the advice
Old Jan 11, 2008 | 12:31 PM
94MR2-T's Avatar
The highest offset I can get is a +35 will it still be possible rolling the fenders to stuff them in there 18x9.5 +35 with 245/45/18? If I do rub is it more common to rub the front or the rear?
Old Jan 11, 2008 | 01:17 PM
I think you'll be fine with +35. Might need to roll the rears just a tad but fronts should be fine.
I've done a similar setup in those offsets.
Rishie
Old Jan 11, 2008 | 02:47 PM
94MR2-T's Avatar
Rishie, Thanks for your help once again!
Old Jan 12, 2008 | 12:45 PM
altiain's Avatar
Sparky!
You are correct - all other things equal, a +20mm wheel will stick out 30mm (1.2 inches) more than a +50mm wheel.
However, all other things are not equal in this case. Not only is the offset 30mm less, but the wheels are also 1.5" wider then stock. That's .75" wider on each side of the centerline, so you've got to add that .75" to the 1.2" you picked up due to the offset change to find that the total width has grown by almost two inches (1.2 + .75 - 1.95").
Those won't fit, not without some massive fender massaging.
Old Jan 14, 2008 | 10:04 PM
kevinD1226's Avatar
they offer thoose wheels in a 48mm offset y not just do that? thoose are the wheels i have and i have no rubbing issues nice choice btw
Old Jan 16, 2008 | 11:25 AM
94MR2-T's Avatar
They offer the rota p45r's in gold with polished lip in +48 offset? Do you have pics of yours?
Old Jan 16, 2008 | 11:42 AM
94MR2-T's Avatar
If i did a 9.5 inch wheel 245/45/18 would I be better off with the +35 or +48 offset??
Old Jan 16, 2008 | 03:38 PM
kevinD1226's Avatar
id do the 48 offset to be safe cause with the lower offset and the 1.5" wider wheel ull be satisfied enough.. probably wont be flush but pretty damn close and u wont need to roll ur fenders.. where if u go with the 35mm offset and the 9.5" wide wheel ur probably gonna be close depending on what tires u end up goin with
Old Jan 16, 2008 | 03:41 PM
kevinD1226's Avatar
have u seen the staggered kit they offer for thoose rotas? they use p45f's up front and p45r's in the rear looks insane! subydude has em $900 shipped to your door when i was thinking of gettin them... im just gonna go with the staggered rota torques... heres a link to what they would look like staggered
http://www.subydude.com/images/prod/...5staggered.jpg
c41250n's Avatar
why dont you get 25+ all around? not to mention hey share the same face, so same concave
i used to have that set of wheels
Old Jan 16, 2008 | 04:17 PM
dillsrotary's Avatar
jersey fresh
I shopped around for P45r's for quite awhile, and I'm sad to say you won't find a version that fits (well fits probably). The the closest I found was 30+ 18x9 through subydude on the evom forums (which I did not purchase). Those rims were made for evo, 350z, etc with a lower stock offset. Safest bet is the P45f's though they are not as concave looking as the p45r's.
Old Jan 16, 2008 | 04:27 PM
kevinD1226's Avatar
they make the p45r in a 48mm offset which would fit just fine
Old Jan 16, 2008 | 04:29 PM
kevinD1226's Avatar
http://www.rotawheels.com/p45r.php
im either blind or the website shows 48mm offset there only cause suby dude dont have it dont mean they dont make em
Old Jan 16, 2008 | 04:30 PM
jersey fresh
I think you're confusing P45r with P45f, so you have a link to that?
