CEL codes
Old Dec 10, 2007 | 01:52 PM
goliat11's Avatar
CEL codes
Hi everyone.
Is there a way to read CEL codes without a scanner?
THANKS
2005 RX8
Old Dec 10, 2007 | 01:53 PM
nope, you'll need a can scanner to get the code pulled.
There are a few on ebay that aren't too expensive that you can get.
Old Dec 10, 2007 | 02:03 PM
Noble Wolf's Avatar
My Eye is watching you
I would suggest scangauge II, you can read and clear CELs and also monitor several info of your motor like water temp, incoming air temp, ignition timing and much more
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
