158 whp wtf!!!!!!!!
Old Dec 8, 2007 | 01:43 AM
Benjamz's Avatar
Tony says, RX8s are GREAT
Unhappy 158 whp wtf!!!!!!!!
yeah so i just bought a 6mt... felt nice... but i wanted to dyno it to make sure it was running up to stock spec... i was hoping that since it passed its "100" point inspection that everything would be good... NOT!!!!!!!!
well what do we make stock... 175 to 180 whp !!!! hell even 170 i think is on the low end ok.....
but damn man... after the last dip in the graph it drops instead of going up..
brought it into the dealer.. friggin coils.....
158 whp 128 wtq not cool at all... rough idle.. stick shift vibrates..
and the car is an 2004 but it only has 21567 miles!!!!!!!!!!!!!!!!!!!!!!!!
anyways.. you think only coils will bring the power down this much...
i have the dyno graph... but i need to learn how to post it on this forum
catch ya later guys
Old Dec 8, 2007 | 01:55 AM
chetrickerman's Avatar
damn thats low. coils are very important to the engine though.
try uploading the graph to photobucket or imageshack and just post the image code on here
Old Dec 8, 2007 | 02:44 AM
tajabaho1's Avatar
Destroying Threads
should be either your coils or plugs, need to see AFR
Old Dec 8, 2007 | 02:53 AM
better ? would be is what is your flash, and what what the last recall done..
taja. what would the afr tell you????? fail again.
Old Dec 8, 2007 | 07:31 AM
Benjamz's Avatar
yeah, i just bought it from the dealer, all the recalls done, they tell me im gonna get 4 new coils, but there not gonna replace the plugs unless it needs it.... also there going to check my liqued filled mounts to see if they contribute to the vibation...
i have all the stickers in the door jam for the recalls and i did get it from oak tree mazda.. so far they have been good...
so now comes the white te-37.. 17x7.5 with 245/45/17 .... the rim is rated small.. it actually physically measures almost 8 wide...
gettin some tien springs.. some light window tint.... the factory aerokit installed... even the front mud flaps...
then ill be good for a while... anyways yeah, ill try and upload the graph today sometime... no afr though.. dyno for free.. my friends shop...... lucky me... hahaa
Old Dec 8, 2007 | 07:33 AM
Benjamz's Avatar
oh yeah, anyone know whats up with the cooling coil mod
Old Dec 8, 2007 | 07:45 AM
Soravia's Avatar
Call Mazada support, give them VIN and ask what stuff has been done on which date. You might have an older flash of the ECU.
Also spark-plugs get more **** than coils, change them. Don't forget to reset your ECU. Also check the ground wire connection. If there isn't enough surface contact to flow hi-amp there won't be enough power to the coils nor plugs. Trust me, that happened to my Nissan and it wasn't fuuny to chase that for 6 months.
Old Dec 8, 2007 | 12:25 PM
staticlag's Avatar
The Professor
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/diy-how-dyno-rx8-132083/
Old Dec 8, 2007 | 12:42 PM
jones75254's Avatar
Is that Engrish? he he
What dyno? stang or jet?
Old Dec 8, 2007 | 01:19 PM
YaXMaNGTO's Avatar
It's a Cavalier
^^ +1
If it's a mustang dyno and we factor in 10% then that gets you to about 174whp on a dynojet... just approximates...
Old Dec 8, 2007 | 01:30 PM
1stgen8's Avatar
They sold it knowing all this and probably thought they'd get someone who didn't know anything about cars to buy it. I bet you got a good deal on it too.
Old Dec 8, 2007 | 05:38 PM
Benjamz's Avatar
i did get a good deal
16k and added a 7 year 100k with 0 deductible... totaaly worth the 2k for this kinda warrenty on a rotary...hahahaha
leather sunroof.. no kit and navi.. navi would be nice but oh well, but the kit is on its way
i only know its at my friend shop called DNR racing.. hes at the old skunkworks place in hayward..
he uses it for the front whhel drive hondas if that counts
and the graph ... the power drops... alot after the 3rd dip in the dyno characteristics of the rx8 motor..
the it tries to go up but stays almost flat 158 whp at 8700 rpm
it looks hella jagged above 7k, but below it looks smooth...kinda normal... just low power..
but yeah,, 16k for a car with 21.5 k miles... awsome!!!!!!!!!
Old Dec 8, 2007 | 06:07 PM
jones75254's Avatar
Get the coils and plugs (if needed) replaced and then go pay $50 at a reputable performance shop w/ dynojet and then come back and let us know.
This way if the readings STILL come out that low then you know its the car and not the dyno/dyno facility. Also be sure to pull the DSC fuse prior to the pulls.
Old Dec 8, 2007 | 07:34 PM
You neeed to pull the fuse when you Dyno.
the car went in limp mode.
Need to dyno correctly.
I got 163 around 6.5K. Pulled the fuse and 198.7 RWHP at 9 kRPM. Ran 5 more runs and it dropped to 198.5. Very consistent.
Old Dec 8, 2007 | 07:38 PM
^ is that your current dyno?
Old Dec 8, 2007 | 07:40 PM
mysql101's Avatar
my car dynoed without fuse pulling or any other tricks.
Old Dec 8, 2007 | 07:42 PM
did you have the DSC button pressed?
Old Dec 8, 2007 | 07:46 PM
mysql101's Avatar
nothing pushed.
you aren't drag racing the car. You don't need to launch it or do anything weird. Just get into 3rd or 5th, then floor it.
Old Dec 8, 2007 | 07:53 PM
true. i planned on dynoing my car in the spring, and i read the whole DIY dyno, so i think im going to try each way a couple times
Old Dec 8, 2007 | 08:01 PM
Jeromie's Avatar
where exactly did u get it dynoed?
Old Dec 8, 2007 | 08:13 PM
you dont need to pull ur fuse to do any dyno
if I were you, I will try to replace the plugs right now, since you're @ 21K miles. and u got a 04, with such low miles, the previous owner probably baby the **** outa the car.
You got 4 new coils already right? replace the plugs and plug wire, they're cheap, plugs you can get a whole set for around 50 bux shipped (Ebay my friend), get some good plug wires like magnore (Spelling) or RB wires.
put some premix in and premium fuel, pull the car out, run the **** out of it on some highway. make sure no cops are around. replace the coolant, go dyno again. see what happens
Im planning to pull my car to Dynojet next week, maybe thursday or friday. I will post mine up
Old Dec 8, 2007 | 08:16 PM
well i shouldnt have a problem with that. but it seems like you will with those cops harassing you all the time
Old Dec 8, 2007 | 09:06 PM
*sigh*
it sucks to be in nyc ... what can I say ~~~~
Old Dec 8, 2007 | 09:13 PM
hah, i can tell
Old Dec 9, 2007 | 03:57 AM
Benjamz's Avatar
"then go pay $50 at a reputable performance shop w/ dynojet "
i had it done at dnr, they are reputable , and ive known dave for 8 years..
but i like for free better... hahahaha
ill ask what kinda dyno he has.. but ....
ill see how it is after the car has its coils replaced... its still sitting at the dealer waiting for the work... im going to canada on the 17th of dec.. my b-day is dec 15... i hope i have it back by then..
damn i got it nov 27... i had it 6 days then i had to bring it back to the dealer..lol
anyways.. i still love this damn car
