View Full Version : Anyone have their motor mounts replaced more than once?
Vasichko 12-07-2007, 10:22 AM For the past couple of days Ive noticed a rough idle, so I think Im gonna replace the plugs and coils since I have just over 27k miles on them.
Hopefully this clears it up, but the symptoms look as if it would be the motor mounts again.
Anyone have these replaced multiple times?
Jedi54 12-07-2007, 11:20 AM I'm about to have it done. I got them replaced about a year ago and now it seems as if I need another mount. :(
MazdaManiac 12-07-2007, 11:40 AM Mine are abused by the turbo, so I'm probably not a good data point.
But, yes, mine keep failing.
They get floppy and sag.
I have one that I filled with urethane in the car right now.
I'm just not so sure I like the vibration.
I'm going to try filling one with 60 Shore instead of 80 and see if it is any smoother.
Jedi54 12-07-2007, 11:43 AM MM: have you tried Mazsport's Motor mounts? (I'm assuming they're different then OEM?)
Razz1 12-08-2007, 07:41 PM I'm about to have it done. I got them replaced about a year ago and now it seems as if I need another mount. :(
Talk about mount... It looks like someone is getting mounted in Jeff's new Avitar!
MazdaManiac 12-08-2007, 08:33 PM MM: have you tried Mazsport's Motor mounts? (I'm assuming they're different then OEM?)
No. Ray has them, though.
I don't really need the space that they provide and my solution doesn't cost me anything.
1stgen8 12-09-2007, 09:19 AM Talk about mount... It looks like someone is getting mounted in Jeff's new Avitar!
Where and the heck does he find all the pics. I'm starting to think he knows alot of the girls.
Vasichko 12-10-2007, 05:50 PM Yeah cause for maybe a week now the idle feels more rough in the shifter and feels like things are moving when I hit certain bumps.
Wonder if one of the techies forgot to do something when putting my car back together when doing the warranty for a throw out bearing.
Vasichko 12-15-2007, 04:04 PM Well took it to Mazda they said they checked everything and everything is ok.
I still dont believe so, the car feels like it shakes and rattles alot more over roads.
If I tap the throttle and let off you can feel it rock back, rock forward, then it does so 2-3 more times with each time getting less pronounced.
Anything else this could be?
nycgps 12-15-2007, 05:23 PM I replaced mine about a year something ago, and I just replaced it again last month, both warranty
DOMINION 12-16-2007, 11:49 AM I'm about to have it done. I got them replaced about a year ago and now it seems as if I need another mount. :(
Yup same here. I got the shakes :( This one will be out of pocket. I'm out of warrenty.
Cody Red 12-17-2007, 12:13 PM where's a good place to buy them? I'm gonna need some soon, and dealer said mine were fine.
nycgps 12-17-2007, 12:17 PM check around, msg onlinemazdaprts and medcentermazda and RosthenlMazda :)
Razz1 12-17-2007, 01:57 PM So, why are they failing?
Poor design?
Or just too much heat?
Vasichko 12-17-2007, 05:24 PM Im actually considering getting the Mazsport motor mounts, I think they are $250.
Try to get the dealer to fix mine and install the other ones when I get time.
