downshifts in tiptronic
Old Dec 7, 2007 | 09:10 AM
nats's Avatar
i have the 4AT and the downshift from 2nd to 1st gear will only change if im going 47kmph (im in australia) or slower. is there any way i can change this to a higher speed with any mods?
Old Dec 7, 2007 | 09:12 AM
chetrickerman's Avatar
what is 47 kmph like 20 miles an hour? well if it is, in the manual (for MT) it says to not shift into first gear above 20 mph because it could cause tranny failure. so maybe its the same thing with AT's
Old Dec 7, 2007 | 10:25 AM
JTtheDude's Avatar
I don't know what it is in kmph but in my 4at it's 30mph you can't downshift anymore. I don't know a way to get rid of that
Old Dec 7, 2007 | 12:25 PM
you dont want to get rid of that. it protects the transmission
Old Dec 7, 2007 | 10:33 PM
thecow135's Avatar
4AT not 6AT so might be different
Old Dec 7, 2007 | 11:25 PM
Old Rotor's Avatar
The 4 A/T wont shift down to 1st till it's about 2.7K RPM's in 2nd gear.
Old Dec 8, 2007 | 08:07 AM
JTtheDude's Avatar
I don't know what it is for a 6AT but here's all gears for 4AT in the US...
Cannot downshift to 1st over 30mph
Cannot downshift to 2nd over 70mph
Cannot downshift to 3rd over 110mph
I too wish you could get rid of that limiter or at least tweak it to increase on 1st gear. I mean if I can hit 48mph in 1st why can't I downshift at say 35-40. I'd be happy with 40 or maybe a little less and 2nd needs to be raised to at least 75 i say. Maybe the torque converter can't handle the shock of the increase in rpm's I don't know. But there doesn't seem to be anything out there currently that can change this like the rev and speed limiters.
Old Dec 8, 2007 | 03:51 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Even though we can shift from 1st to 2nd @ 48mph, you wouldn't want to down shift from 2nd into 1st @ a speed higher than the 30 mph limit. The sudden centrifugal load placed on the TQ from a high speed 2nd to 1st shift would destroy the OEM TQ.
I don't know about any of you but I don't want shrapnel slung trough my legs.
just be happy with the imposed 30 mph shifting.
Old Dec 8, 2007 | 11:37 PM
tajabaho1's Avatar
Destroying Threads
on the 6 ATs you can only shift to 1st below 20mph, and seriously, good thing too, the 6MTs you should only downshift to 1st below 10mph, if not you risk destroying your synchros
just do it
Old Dec 8, 2007 | 11:41 PM
G3tR3DDY2GR3DDY's Avatar
not with proper rev-matching techniques there is no risk in any downshifting, but i guess not all of us have those skills...
Old Dec 8, 2007 | 11:52 PM
tajabaho1's Avatar
Destroying Threads
^ i tried, still in 1st, it really isn't recommended
and for the argument's sake ATs cant rev match =.=
Old Dec 9, 2007 | 05:08 AM
nats's Avatar
ok thanks for that. Just wanted to know.
Old Dec 9, 2007 | 12:15 PM
R888's Avatar
WedsSport Member
2nd gear to 1st gear
Must be under 50km for the tranny to response.
Old Dec 9, 2007 | 12:53 PM
mdw1000's Avatar
I'll snap his neck.
I've found you can do sort of a psedo rev match. If you blip the throttle just after tapping to downshift, it makes the downshift seem a bit smoother. But I've only tried that when I'm downshifting and not on the brakes, or have the time to let off the brakes. Don't trust myself to heel and toe
Old Dec 9, 2007 | 01:30 PM
JTtheDude's Avatar
I rev match my downshifts all the time in my 4at I've done it so much that it's just habit now and now I"m getting really good at it. going down to first at close to 30mph is the hardest but if you rev match the rpm's up to about 4-4.5k it will be smooth I've done it numerous times.
Old Dec 9, 2007 | 02:01 PM
Spinning Sushi's Avatar
I <3 Sushi
You can rev-match an AT? Is that even possible?! Please explain.
Old Dec 9, 2007 | 02:09 PM
Jasonawojo's Avatar
From what I've read, there is enough of a delay in the manual mode shifting that you can blip the throttle after hitting downshift prior to the downshifting actually occurring. Thus helping to bring the revs up as needed for the lower gear.
Old Dec 9, 2007 | 02:12 PM
I <3 Sushi
That's interesting. I'm pretty sure that it's easier with the 4AT rather than the 6AT considering how the gears are longer and not as refined.
Old Dec 10, 2007 | 08:58 AM
JTtheDude's Avatar
Yeah exactly, you press the down button or use the shifter whatever, then there is the slightest pause where you blip the throttle and depending on the gear depends how much you blip, if you blip it right the gear will grab at about the right rpm and it will be a nice smooth shift. If anyone here is in the Dallas area I'm in Plano and I can show you anytime I do this everyday everytime I drive and I'm quite good at it now. this is in a 4at I've never driven a 6at to try it
Old Dec 11, 2007 | 09:25 AM
09Factor's Avatar
There is a long enough pause in the 4AT to rev match. I do it all the time.
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
MANIACman
Nov 11, 2015 10:58 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
teamdipngo
Sep 14, 2015 02:47 PM
talonhart2
Aug 26, 2015 04:14 PM
